  1. TSBs are published (and sent out to subscribers) every quarter - so I am expecting them any time now.
  2. Not for the C2 (G96/00 and G96/01).
  3. There is no placement guide in the 997 Service Manual or the Aerokit Install TSB. Here is what the service manual has for the (997) Carrera and Carrera S. Carrera 1. Find the middle of the lid. 2. Position logo Carrera with the dimensions A and C Carrera logo dimension 129.6 mm+/−1 mm and B Carrera logo dimension 45 mm−1 mm and stick on lid. Carrera S 1. Find the middle of the lid. 2. Position logo Carrera with the dimensions A Carrera S logo dimension 175.6 mm+/−1 mm and B Carrera S logo distance 45 mm−1 mm and stick on lid. 3. Position logo S with the dimensions C Carrera S logo dimension 175.6 mm+/−1 mm and D Carrera S logo distance 39 mm+/−1 mm and stick on rear lid.
  4. You could use the Carrera Aerokit Cup harness here. Or rewire the pins as described in that same post.
  5. It would have been nice if you told us everything to start with... If you have a lot of smoke then oil (and/or coolant) is burning and you are going to get lots of O2 sensor codes (which you are). You need to determine and correct the cause of the smoke. Oil smoke smells like oil and coolant smoke smells sweet. or... perhaps the oil seperator was not installed properly and has slipped off?
  6. Litronic bulb change Removal 1. Switch off the light. Release the headlight housing and pull out forwards slightly. 2. Disconnect the electrical plug connection of the automatic headlight beam adjustment and remove the headlight housing. 3. Release and open the cover with control module. Unscrew the electrical plug connection on the gas discharge lamp (bayonet lock). 4. Rotate lamp fastening anti-clockwise (bayonet lock) and remove together with the gas discharge lamp. Installation 1. Install a new gas discharge lamp. Lock the cover with control module and insert the headlight housing in the wing. 2. Engage the electrical plug connection of the automatic headlight beam adjustment and lock the headlight housing in the wing. 3. Carry out function check of the headlights.
  7. Some functions can be preset using a PIWIS and some can not. Sometimes cars come with some options preset and sometimes not. IMHO... the main reason for hooking up a PIWIS (or PST2) after an install is to see if there are any trouble codes generated by the install. You won't really know if it is "required" until you try. Thank you for donation - it all helps keep to this site running.
  8. Porsche does not show that as a valid code for their cars. From the Standardized DTC to SAE J 2012 (DTC-Diagnostic Trouble Codes) generic code list that means: O2 Control (Bank 2) System too lean
  9. Porsche specs on those size wheels (for a 997 C4S) are: Front offset: 55 mm Rear offset: 67 mm or on a slightly smaller front wheel Front 19 x 8 offset 57 mm Rear 19 x 11 offset 51 mm
  10. Not as detailed as the pics but, it is your Owner's Manual too.
  11. What spoiler are you using? The TT/C4S aerokit or 3rd party? If it is 3rd party then does it have a stop light?
  12. The compuer/CD unit still comes up in the price list. 996.642.122.12.EWD COMPUTER-NAV UNIT (MY02 only) $1553.66 (as of January 2006)
  13. No, that is for CDC-4 and MY03 and newer cars.
  14. Navigation disks are available from NAVTECH. Their customer support number is 1 (888) 628-6277.
  15. Not necessarily, if there is enough carbon then it will absorb gas and make the mixture too rich on warm starts. Bottom line is that if it's dirty clean it - it can only help.
  16. We have added new Maintenance Checklists for the Boxster (986). Check it out here.
  17. If your car is egas then it should look just like the pic above. On egas cars there is nothing to disassenble. Just open the butteryfly and clean it throughly with carb cleaner.
  18. http://www.renntech.org/forums/index.php?showtopic=7067
  19. Do a search here for "coolant tank" - unfortunately a very common fault.
  20. http://www.renntech.org/forums/index.php?showtopic=245
  21. The Boxster maintenance should be pretty much the same as the Carrera - based on model year. I just got a newer version of the Boxster service manual - so I'll have to check there. Edit - Just added the Boxster (986) Maintenance Checklists. You can find them here.
  22. If you use the factory recommended tires/tire sizes (for the wheel size) you will not have any problems.
  23. Center console compartment or door compartment?
