  1. Hmm... I guess it could be a bad cluster. Still under warranty?
  2. If you wiggle the light switch does anything change? Headlight switches have gone bad on a few cars.
  3. I think he is talking about the one up front next to the condenser. But is is not listed separately in PET either.
  4. Yes - same for 986, Air Conditioning -> Modify Coding (like it says at the top of the screenshot).
  5. Highlight Temperature unit hit >> (coding key) and change.
  6. Loren, I want to get my dealer to do the switch from Fahrenhuit to Celsius on the AC/Heater control. Can you please provide instruction for the PST2 process. He didn't know how to do it. I have an 03 Boxster S. Thx Have you tried this? Press and hold the recirculation button. Then press the temperature up ("+") button to switch between degrees Celsius & Fahrenheit on the Climate Control Temperature and Instrument Panel Outside Temperature displays.
  7. Coils for sure. A bad cat could ruin the O2 sensor. The DME can not compensate for all those errors.
  8. These alone would cause misfires and fault codes.
  9. The Durametric software can not change mileage in the DME or cluster. Even a dealer/shop PST2 or PIWIS tester can not change mileage on a cluster that has more than 52 miles on it. I am sure there are people out there that can still alter mileage - legally or not.
  10. I have seen the wire come out of the connector mount for the headlights in at least a couple cases. After you take the headlight out inspect the connector and pins on the socket (still on the car) to see that they are secure and pushed in all the way.
  11. Thanks for that.. I had the O/S cam cover mended last Nov at the dealer so perhaps they did a bad job...I will take it back. If they replaced/resealed the camcover and didn't check the oil tubes shame on them. There are new o-rings for the early MY99 Carrera's that have almost eliminated all oil tube leaks.
  12. If you were in the US I would suggest: http://www.paintscratch.com/
  13. Sorry, let me clairify... That is the correct part number for a MY99 - 01 Carrera 3.4 liter. I think the Boxster has a different venting system so I am not sure how that will work. You might PM or email Monster Boxster and see what he did when he put a Carrera motor in his Monster Boxster.
  14. According to the parts list that part number (996.107.023.51) is for a 97 Boxster 2.5 liter. It was replaced by p/n 996.107.023.51 oil separator and 996.107.145.06 vent line. That has been replaced by 996.107.023.02 which has been replaced by 996.107.023.03 and I think you still need the vent line.
  15. Any D2S bulb of 35 Watts should work.
  16. Ask for a certified 3rd party dyno report of before and after the upgrade.
  17. Is that for the S or non S or are they all the same? Thanks for this bit of info. I've been looking around for this for sometime :) Boxster rotor minimum thickness limits (after any machining) Front: 22 mm Rear: 18 mm Boxster S rotor minimum thickness limits (after any machining) Front: 26 mm Rear: 22 mm
  18. Yes, that is what most folks do when they switch to the Design Key.
  19. You might try calling Becker and tell them your problem and then ask them if they can verify the code. I think they normally charge $35 for this.
  20. Range 1 means nothing - except the that the rev limiter is doing it's job. Range 2 "can" damage the engine. Range 2 are most often caused by missed downshifts or spinning the car and not putting the clutch in. There was speculation that "ignitions" meant actual firing of each cylinder. That would mean that 6 "igntions" would be one complete crankshft revolution. If the car is running fine with Stage 2 occurances then it is likely fine. Just be aware that a dealer and/or Porsche can (but does not in many cases) use numerous Range 2 occurances as "abuse" for any warranty claims.
  21. Normal - that is exactly what it is -- hot metal cooling down.
  22. Yes, I am hoping to finish my long term evaluation of the Durametric Software soon. I personally see a need for two of the four you mention. The OBD-2 software is really good for tracing (graphing) O2 sensor performance and looking at real time DME (only) data. It can read (and reset) only DME fault codes. The software is updated every two to three months - and updates are free. As a bonus it also works on my (other car) Mercedes and my wife's Jeep. For $123 it is a no-brainer. The Durametric Software can read faults in the DME, Alarm, Airbag, ABS, Seat memory, Heating/AC, Tiptronic and more. It can reset those faults in all but the alarm system. It can also read real time data and they are constantly updating it and adding new features. So far the updates are free which is nice with all the added functionality. For the "introductory" price of $197 again this is a great bargain. I don't expect their "introductory price" to last too much longer. The only tool that can do all (and more) of what these two do is a PST2. Latest prices for used PST2's on eBay are still running well over $3000.
  23. Have a look at these two threads where Tool Pants explained over revs Stage 1 and Stage 2... http://www.renntech.org/forums/index.php?s...indpost&p=11317 http://www.renntech.org/forums/index.php?s...findpost&p=5243
  24. DME 5.2.2 - Boxster (986) MY97-99 DME 7.2 - Boxster (986), S MY00-02 DME 7.8 - Boxster (986), S MY03-04;
  25. M7Z -- GT Silver Metallic
