  1. The Cayman service manual is currently only available using a dealers PIWIS tester. If you are lucky you can find a dealer with a PIWIS that has a printer attached and get them to print out that page. If you do please post the page here.
  2. I think you just carefully pry it up to pop the clips loose. I think you may need to take the bumper cover off to do that though. The service manual shows it with the bumper cover off the car.
  3. or try 996.424.981.23.G10 Gear shift knob in aluminum and leather (option X97) -- MSRP $322.69 (as of Feb 2006)
  4. 996.552.417.02.A03 Vent Rose -- MSRP $11.26 (as of Feb 2006)
  5. There are 5 different part numbers with up to 8 colors for each. Please tell me year and color of your vent and I'll get you the exact part number.
  6. ...or just use the link to Car Care on the Links page. :)
  7. 996.424.075.05.FGW Shift knob in Metropol Blue and Silver -- MSRP $199.18 (as of Feb 2006)
  8. I don't have the tech books for MY99, 00, or 01 but in MY02 the front axle cross member was secured at its rear fastening to the body (arrow) with two bolts instead of one.
  9. Coolant is yellow/green in color - smells sweet and tastes really bad. Coolant tank and/or cap failures are fairly common. Bad oxygen sensor? Could be but I would ask him to read out all the P-codes and post them here.
  10. WKD.964.050.91 964 Owners Manual (in Spanish) -- about $40 US WKD.964.020.91 964 Owners Manual (in English) -- about $40 US
  11. Paul, It is hard to say without more info. Does the airbag light and seat belt light come on with the ignition in the "on" position? He could have even removed the seat belt warning light too. If you want I can hook up my PST2 and see if their are any airbag or seat belt faults. Drop me a PM if you wan to do that.
  12. 996.552.425.00.A01 is a blank cover.
  13. Any P-codes? Did you check the fuel pump for output?
  14. Take your pick... http://www.renntech.org/forums/index.php?showtopic=5770 http://www.renntech.org/forums/index.php?showtopic=5200 http://www.renntech.org/forums/index.php?showtopic=6563 http://www.renntech.org/forums/index.php?showtopic=5010 http://www.renntech.org/forums/index.php?showtopic=573 http://www.renntech.org/forums/index.php?showtopic=670
  15. Drive the car and see if it goes out. Did you check the fuse? (C19)
  16. Are you sure it isn't 236 - 18" tires? I know some of mine were hard to read...
  17. The difference (I wasn't very clear above) is that in the Litronics system the high beam primary is Halogen and there is only a partial mix in with the Xenon lamp. In the Bi-Xenon system the lens is used to widen the beam path for high beam. So the primary high beam (as well as low beam) in the Bi-Xenon system is the Xenon lamp. In this case the Halogen lamp is just an additional beam with high beams only. Porsche states the advantages of the Bi-Xenon system introduced in MY02 as: Order guide option numbers do not always equal parts list option codes as many times they are sold as "packages". What does the sticker under your front hood say? M601 or P74? Either would be still be correct.
  18. Maybe your dealer has the parts in the wrong bin? Like I said, I find no reference or cross-reference to 996.799.541.00 for a replacement part.
  19. 996.541.541.01 is for MY01 and older 996.541.541.02 is for MY02 and newer 996.541.541.00 does not exist in the parts list or any of the old price lists I have (back to 2003). I have a MY99 coupe and mine is about 1/2 inch wide. How wide is your trim piece?
  20. This has been covered many many times here. Next time please do a search on "coolant". The results will likely be more than you want to know :lol: http://www.renntech.org/forums/index.php?s...indpost&p=18090 http://www.renntech.org/forums/index.php?s...=findpost&p=554
  21. Did you read the Maintenance Checklist here? Beyond that I would look for coolant tank leaks, RMS or any other engine oil leaks, tightness of the swaybar mounts, and if your brake fluid has not been changed in the last two years it should be.
  22. For example... If your VIN starts with a number lower than 98XS6 20208 then you would use the first part (996.341.158.09) if your VIN 98XS6 20209 or higher then you use the second part number (996.341.158.10) and the additional part it suggests. If you call or email Sunset Imports (Porsche Parts at Dealer Cost) they can explain t to you in more detail. You also know you will need some special tools to change the wheel carrier?
  23. Item 5 is: 997.553.843.00 Sound absorber (left) 997.553.844.00 Sound absorber (right) Are you sure that is the part you want? Perhaps you could post a pic from your car...
  24. Both are a good choice (IMHO). Most of the Cup Cars are running either the GT3 (race) swaybars or H&R. Seems to me the harder decision is what size - but then that depends on wheel and tire size/types and how you want the car to handle.
  25. Do you mean item 25 (cover, shift gate)?
