  1. 996 612 978 00 is the just wiring for the PSE switch (not the rest of the PSE).
  2. If it were just the lights I would say light switch - but the other items make me think it is the ignition switch.
  3. All except 996 612 978 00 are for MY02-04 996. 996 612 978 00 will fit MY98-04.
  4. The seat harness(es) all have connectors that can be unpluged. Some are almost puzzle like but they all come apart so you can remove the seat and inspect everything. If the wire itself is not damaged then taping should work fine. I would also put a tie wrap on the wire so it stays out of harms way.
  5. Worth a look. You will need an E12 (external torx) socket to remove the seat. Be sure to disconnect the battery and remove the key from the ignition before removing the seat - otherwise you will get an airbag light.
  6. So you are talking about E3 a 30 amp fuse? If so, the seat is the only thing on that fuse.
  7. 1. Sport suspension came on all C4S - US and RoW. 2. X73 is only recommended for MY03 and newer. I've seen for about $2500 plus installation. 3. I do not know if it has the proper emission vents/returns for the US. You are talking about US? 4. Perhaps someone else can answer that one...
  8. It is hard to miss. The ICV is a solenoid just on the left of the throttle body. It is held on by two allen head screws and has a delicate paper gasket (don't lose or damage the gasket) between the solenoid and the throttle body. Cleaning works sometimes - but if it is too gummed up then it will need to be replaced.
  9. There was a TSB in 1999 that describes an inner door lock release problem. Does the door release work from the inside (when pulling on the handle twice with the doors locked)?
  10. In the US if it is a formal government recall (as opposed to a Porsche Workshop Campaign) then it shows up on the US government recall website (here).
  11. Yes, and the DME changed from 5.2.2 to 7.2 in MY2000 (mainly for egas) and to 7.8 in MY03. The MY03 and new cars also support more controller-to-controller communication (i.e. new style instrument cluster, etc.) via CAN as of MY03.
  12. Sorry, I don't find anything in the 1988 service manual. Over the years the logos have pretty much been centered similar to above.
  13. Hold the switch all the way down (second click).
  14. Those part numbers are the GT2 turbos. They are much less than US MSRP. The US MSRP for each is $3022.65. As with anything on eBay - Let the buyer beware.
  15. From the service manual (programming with a PST2): "The adjustment function of the seat, mirror and lumbar positions via the hand-held transmitter is correct only if the radio code and the transponder code of a hand-held transmitter are each stored at the same position in the alarm system control module. In this case, it is first necessary to identify and delete the stored transponder code of the lost or faulty hand-held transmitter. All remaining vehicle keys are required for this purpose because all transponder codes are erased during the deletion function. The transponder code of the vehicle key is displayed under 'Current transponder'. Press the F3 key. "All codes will be deleted" appears on the screen; confirm with the F7 key. Insert the vehicle key equipped with the new hand-held transmitter into the ignition lock and switch on the ignition. Establish communication between the 9588 Porsche System Tester II and the control module. Select the position (1, 2, 3,or 4) with the arrow keys (uparrow) and (down arrow) and press the F8 key. The transponder code of the first hand-held transmitter has now been taught. Remove the key and repeat the process for the remaining hand-held transmitters......"
  16. One end of the fuel filter has a special compression fitting. The other end the hose is permanently attached and has a similar connection point further down the hose. When you replace the fuel filter it comes with a new short hose on it.
  17. http://www.renntech.org/forums/index.php?showtopic=1827 http://www.renntech.org/forums/index.php?showtopic=354 http://www.renntech.org/forums/index.php?showtopic=1071 http://www.renntech.org/forums/index.php?showtopic=4589 http://www.renntech.org/forums/index.php?s...ost&p=29623
  18. There should be an option list sticker on the underside of the front trunk. Write the numbers down then look them up on the option code lookup tables here. If you don't see option 030 (sport suspension) then you have a stock suspension.
  19. The service manual only covers through MY05 (so far) which does not show that option. They just show the 11 screws to take the lid liner out. It shouldn't be that hard to figure out. Do you have a picture you can post?
  20. The only "parts" should be Drei Bond silicone - Type 1209 and loctite 5900 sealer and some of the micro-encapsulated (self-sealing) bolts. Perhaps the o-rings on the sparkplug tubes. I think the muffler on that side needs to come off and you will need a second person to position the cams while you re-attach the cam cover. Porsche shops have cam holder tools but most say they don't use them. I would guess 4 hours or less with the right tools/hoist - so their estimate seems high to me.
  21. That fuse should be 15A. It is for the control unit for central locking/alarm, power windows, and inside light.
  22. And the fuse row and number that blew? Top row is A, second row down is B, etc. Fuses are then numbered left top right starting with 1. Your radio code is usually in with your manuals. If not, PM me with your radio serial number.
  23. You hold the switch down for 10 seconds after a full upward movement and then you do the same for a full downward movement.
