  1. "Remove existing fuel tank cap. 2.1 Open fuel filler flap on the vehicle (refer to Owner's Manual). 2.2 Push pin into the expansion rivet with a 2.5 mm punch. 2.3 Remove expansion rivet from the bore on the fuel filler flap with side cutters or pliers." It is all covered in a 4 page TSB.
  2. Todd, I think you will find your answers here.
  3. 1. Remove plastic plugs and undo the hexagon socket head bolts 2 from the sill by approx. 4 - 5 threads. 2. Lift sill 1 upwards out of the bottom support with a plastic spatula and press out. Check fastening clips 4, replace if necessary.
  4. Yes. http://www.renntech.org/forums/index.php?s...ost&p=14457
  5. I would put a good OBD II scan tool on the car and graph the O2 sensors as well as the TRA and FRA. Otherwise we are all shooting in the dark...
  6. Thanks for the great tip! :thumbup:
  7. See the reply right above yours...
  8. Yes, that is why I clarified that a 3.4 is a 3.4 and a 3.6 is a 3.6. If you are going to compare then use apples and apples - a C2 (or C4) vs C4S same model year with the same engine. ;)
  9. The C4S has the same engine as the C4 and the C2 - 320 hp (from MY2002). The C4S does come with the sport suspension as stock and is (in the US version) 10mm lower. C4S also gets the larger TT (steel) brakes.
  10. I think you are looking for the seat well carpeting. 996.551.021.00.M30 Rear seatwell carpeting in Boxster Red -- MSRP $649.79. Check with the folks at Sunset Imports (Porsche Parts at Dealer Cost) for better pricing. If you decide to do this please take some before and after pics. I know someone that also has a Boxster Red interior :rolleyes:
  11. If you remove the cover over the battery and the cover over the washer tank filler - you will see the wiper drive mechanism. Check the two connections (red arrows) and make sure they are not loose or stripped.
  12. Here it is on Amazon. I don't know of a UK supplier - I would try auto parts stores. HEET on amazon
  13. If you have water in the fuel - why not use a fuel dryer like HEET. That has worked for me and is a lot less trouble than draining the tank.
  14. The correct part number for your model year is: 996.341.053.16 -- MSRP $303.13 each. You might want to check with Sunset Imports (Porsche Parts at Dealer Prices) for a better price. Remember you would need an alignment after replacing these parts and if you have PSM you will need to check the steering-angle sensor calibration.
  15. That image is for a GT3 (or GT2) with adjustable camber shims. Do you want the stock (non-adjustable) part or do you want the race/track part? TRG and a few others sell the track parts.
  16. Yes, I think a couple of other members have that set - and recommend it. I see a sale price of $79.00 for that kit.
  17. Probably 17 mm rear and 5 mm front.
  18. Porsche tool 9560 (part no. 000.721.956.00) -- MSRP $209.78 I think you can find a similar tool via third party.
  19. M415 is wider rear track with spacers.
  20. Please let the image completely upload before submitting the post - thanks.
  21. Uh... he posted in the 996 area. PeterC4 -is this a 996 or 997?
  22. If you have a misfire you likely have a fault code or two. If you have a code reader read out the codes - some auto parts stores will read your codes for free too. Report back here what your codes are.
