  1. Model Year and model please...
  2. I posted the link to the instructions and the full discussion of part numbers 5 posts up. http://www.renntech.org/forums/index.php?showtopic=493
  3. Yes, but you will need to cut the bumper mount back to fit the curve of the TT bumper. This has been covered here many times...
  4. Do you have to have the switch rekeyed to use your existing keys? How hard is it to DIY If you replace just the electrical part of the switch then nothing has to be re-keyed or re-programmed. If you replace the whole lock assembly then you do have to re-program.
  5. You can disconnect the wires and test the lights - but it is likely the switch. It's not hard to replace - just a little hard to reach.
  6. Good to know. Since its new to me I dont need to point out the obvious that I never got a post card. I'm going to have to go back and give them hell since they saw the car last summer. I put the car into service and I'm not seeing a compliance notice. How wonderful. My seal isnt cracked like slb's cap, but I suppose I could investigate the fuel vent. Any quick way to test that? If the seal leaks bad enough it will cause a CEL.
  7. Is there anything on the ICV that needs cleaning on an egas car? I dismantled mine and it looks quite different from the non egas ones. Mine looks like a round disc. I ended up just cleaning the throttle body which solve the problem anyway. eGas cars do not have an ICV. The idle is controlled by small movements of the throttle butterfly - so IMHO it is more important on an eGas car to keep the throttle body and butterfly clean.
  8. Well it is up to you. We suggest the dampers but I've heard of folks reusing them - worst case you will have some squeal. If the sensors turned on the brake pad light then one or more of them will have to be replaced (or jumpered). You would need to look a the pin and spring to see if they are worn.
  9. http://www.renntech.org/forums/index.php?s...emarkers++flash
  10. http://www.renntech.org/forums/index.php?showtopic=11942
  11. Same transmission in my Mercedes CLK55 AMG and Mercedes says "Electronically controlled five speed automatic transmission 722.6 is filled with a newly developed special transmission fluid and is considered to be "filled for life", ie: does not require fluid level checking or fluid change during scheduled maintenance procedures." So I guess Porsche, BMW, and Mercedes are all wrong? Each person is entitled to their own opinion -- but it is just that -- "your opinion". I am not starting an argument - I am just stating that each person needs to make their own decision on items like this.
  12. Sorry, that is not a good part number. The latest tank for a MY00 Boxster is: 996.106.147.07
  13. Thanks! :thumbup:
  14. Those part numbers do not come up anywhere that I can find. Are you sure those are the part numbers?
  15. Porsche says 90,000 miles. http://www.renntech.org/forums/index.php?a...de=maint_us_add
  16. Did you check D8 and E6 also? D8 is the radio and D9 is the other audio option package. E6 is the CD Changer fuse.
  17. If you have a laptop computer buy the Durametric Software. It can read codes and reset them - plus a lot of other useful information. http://www.durametric.com
  18. What is the last part number of the tank you have? There have been 4 or 5 tanks.
  19. The gas cap problem was a mandatory US Recall. So the original owner should have got a postcard and the next visit to any dealership should have had it replaced. They were also required to put a recall compliance sticker on the underside of the engine cover. I got mine replaced in July 2002.
  20. Esso ATF LT 71141 is correct Porsche Part Number: 999.917.547.00
  21. Anything different of you jiggle the key in the ignition? If so, it is likely the switch.
  22. I would look at the heat shield on that side first then the muffler.
  23. Try locking the car using the key - then unlock it using the key. Try to start it again. Then see if the symptoms change...
