  1. Those will all fit fine. Alcantara is readily available but I think red stiching would be special order. Check them out at: Carnewal.com
  2. If you want rotor specs I will need model year and exact model...
  3. I wouldn't worry about 5525 - every TT w/Tip I have looked at had that same code. The car will run at low RPMs fine with the MAF disconnected. What you will lose is high RPM - but the turbo may mask that somewhat. It sure sounds like you have no MAF signal and any dealer should be able to test that easily with a PST2 or PIWIS tester. If it is not the MAF then they should be looking at the connector and wiring or the throttle jacking. The diagnostic manuals lists: P0103 - Possible fault cause -Intake air system on pressure side (between turbocharger and engine) leaks - Short circuit to B+ (B+ is + 12 volts) - Mass air flow sensor faulty - Throttle jacking unit faulty The reading on a Porsche System Tester should tell them if the MAF is changing with engine speed (intake air flow).
  4. I think so - but Richard Hamilton should be able to tell you for sure.
  5. Are you sure the MAF id connected -- you get the same symptom if you unplug the MAF.
  6. We have added the MY08 Owners Manuals for: MY08 Cayenne S Owners Manual MY08 Cayenne Turbo Owners Manual Enjoy... :) (edit: also added Cayenne PCM Manual)
  7. Do you have a picture of the pattern (so I get the right wheels)? Are these the 19" Turbo-1 wheels?
  8. Tool Pants covered the whole (wiper delay) thing here
  9. You can get them from Becker for under $2.00 each (last time I checked) plus shipping. You can also usually find them on eBay for $10.00 or more! Where are you located? another member here might loan you their set... Thanks, Loren. What are they actually called so I can do a search online. Clear Lake, Houston, TX if anyone is near me, please let me help me out. Becker radio keys. (photo 1 courtesy - Tool Pants, photo 2 courtesy Tom Morris)
  10. These are all special order items. Try Sunset Imports (Porsche Parts at Dealer Cost) for prices and delivery.
  11. Well, there are still a lot of variables that make up the "odd and ends". How many plastic rivets will you break taking the wheel well liners off? What type of front bumper will you use? some will require different mounting hardware. Do you have the (pin removal) tools for the electrical re-wiring? and possibly plug/socket replacements. Porsche does not make a kit - so any kit will be after market -- my guess is you will still have some fitting to do.
  12. Might I ask why you want 997 mufflers on a 996? I don't think the sound would be much different - since the engine is the same.
  13. You can get them from Becker for under $2.00 each (last time I checked) plus shipping. You can also usually find them on eBay for $10.00 or more! Where are you located? another member here might loan you their set...
  14. You will need front fenders, bumper, headlights (and re-wiring) plus some small odds and ends. It can be done - but it won't be cheap.
  15. http://www.renntech.org/forums/index.php?s...ost&p=43016
  16. I just noticed this - it has been moved.
  17. My bad I was looking at the Boxster S. On the Boxster S they are the same as the Carrera. A standard Boxster is different.
  18. A CDR-??? And do you have an amp?
  19. hey loren ihave a 996 c4s 05 which wiring harness can i use or how do i rewire the stock If you are using a Porsche Aerokit package then the harness above is included. If you are using an after market spoiler - the above harness should also work for most.
  20. For a MY05 C4S you will need to buy the small rear light harness - one per side. 996.631.447.00 tail light wiring harness (for both left and right - 2 required)
  21. For what model? what model year? Left or right? or do you mean center brake light? Please be more specific...
  22. I think Tool Pants posted a picture of the that measurement once before but I can't find it now. Basically, it if you put your micrometer on a horizontal fixed point (like a jack stand or attach it to a suspension piece) so that it just touches the rotor. Then you slowly rotate the rotor -- the variation should be less than the spec above. So that is really rotor wobble. Some more sophisticated micrometers can measure both sides at the same time.
  23. Most folks just put a piece of tape to mark where the old ones are - then put the new ones on using the tape mark. If you have already removed the old ones then you will need to find another Boxster to measure on (as that measurement is not specified in the service manual).
