  1. Folks - please just keep it civil here and keep it on topic. Everyone is entitled to their opinion...
  2. From everything I have heard (to date) the 997 seal is your best choice.
  3. If it is up (all the time) then chances are there is air in the system. It is just a bleed valve and Cup Car racers leave it up most of the time.
  4. Offset Explained - check out this link http://www.renntech.org/forums/index.php?a...DE=02&cat=4
  5. That is okay - and welcome! With over 54,000 posts here many topics have been covered in a great deal of detail... enjoy! :welcome:
  6. That will depend on the wheel offset. Email the seller and ask them for the wheel offsets -- then we can help.
  7. Have you done a search here? These same faults have been discussed many times here before. Just search for p1128 and p1130.
  8. PCA has an "Excellent" comparison (IMHO). Much more detail and testing than I have ever seen (other than pure racing teams).
  9. Only if they will let you put the locking assembly in (at their location since you can't drive it until the keys are programmed). I would buy a spare key from Sunset Imports (Porsche Parts at Dealer Cost at the top of any page). That way if their are any questions about the authenticity of the key - you have a Porsche dealer to vouch for it and you.
  10. Yes, the key info (transponder data) will need to be transfered using a PST2 or PIWIS tester.
  11. If your battery is 4 year old (or older) then it likely needs replaced. Many auto parts stores will load test and specific gravity test your battery for free. If you had other electrical problems I would look at the ignition switch - but the battery is the beat place to start.
  12. As they say in their ad - "the rears will require spacers for C4S".
  13. Many times information on newer models gets added tot eh service manuals 2-3 years after the model manual is introduced. My 996 was not complete until almost 4 years after I bought it (there are 99 supplements for the 996 series). Sometimes dealerships that have a POSES subscription can get online updates directly through their PIWIS tester.
  14. It is a vacuum filling system. So it pulls coolant in without trapping air bubbles.
  15. The Retail Price Search feature (for our Contributing Members) has been updated to reflect March 2007 pricing for the US (only). We try and update this on a monthly basis as the price lists come available to us. For March 2007 the price lists support - US: 211,261 parts Canada: 209,209 parts (December 2006)
  16. Check the connector on the sensor and clean it if it is dirty. If it fails again after that then you will likely need to replace the sensor.
  17. The wiring harness is different between the halogen and bi-xenon. They are not interchangeable.
  18. Remove: 1. Pull off hot film mass air flow sensor. Push the plug downwards and press the grooved surface at the sides. Pull the plug up and off at the same time. 2. Pull off the connecting hose between the left turbocharger and the intake pipe. Unclip the retaining clips using a screwdriver and pull out the hose. Refit the retaining clips immediately. 3. Undo hose clamp. Undo the hose clamp −arrow− between the air cleaner housing and the intake pipe. 4. Remove air cleaner housing. Unscrew the fastening screw M6 x 34 at the rear of the air cleaner housing. 5. Tilt air cleaner housing outwards. Tilt the housing upwards and to the right by 90° and then turn the housing to the left by approx. 90°. 6. Unclip the hot film mass air flow meter cable. a. Open the omega clip on the left side of the air cleaner housing and take out the cable. b. Take the air cleaner housing out of the engine compartment. 7. Open air cleaner housing. To do this, open the screws −arrows− and pull the two housing halves apart. 8. Take out the cleaner element. c. Take out the air cleaner element. d. Wipe out the two housing halves with a cloth. Install: 1. Insert filter element. a. Insert the filter element into the cleaned air cleaner housing. b. Retighten the two air cleaner housing halves with the screws. 2. Clip in hot film mass air flow sensor cable. Insert the cable into the omega clip on the left air cleaner housing side and then close the clip. 3. Place the air cleaner housing in the engine compartment as shown and move into installation position. c. Turn the housing to the right by approx. 90° and push the rubber hose over the flange. d. Swivel the housing downwards by 90°. 4. Tighten the fastening screw M6 x 34. Tightening torque: 10 Nm (7.5 ftlb.) 5. Tighten the hose clamp on the connecting hose. Reconnect the plug on the hot film mass air flow sensor. Note - The plug must engage audibly! 6. Attach the connecting hose between the left turbocharger and the intake distributor. Note - The hose must engage audibly!
  19. Scouser has updated his excellent VIN Decoder. The VIN Decoder is here. Now includes a built in help and explanation of each value. Many thanks to Scouser for his continued efforts, work, and updates to this fine tool! :clapping:
