  1. You would basically be building a GT2 since your car does not have 4 wheel drive. A 2WD Turbo/GT2 is a handful even for an experienced driver (IMHO). I do not know if the intercoolers will fit under narrow body rear fenders. Other concerns would be a fuel delivery (TT has always had the returnless system that your car does not have) and cooling (needs larger ducts and radiators). Might be an easier project in a C4S but a narrow body would have some real challenges. All IMHO of course...
  2. Well, OBD II is different for Europe than the US - in the US you will get a CEL with the MAF disconnected (in a day or so). If the car runs better with the MAF disconnected then that is one of the problems. I think you need to replace it and see if any other codes come up.
  3. They operate together in two stages. At the prescribed temperature both sides turn on to stage 1 (lower speed). If the temperature continues to rise to the next level OR if the AC is turned on the both fans turn on to stage 2 (fast speed). If a ballast is bad (on one side) or a fuse is blown or the fan motor is bad - then the fan on that side will start.
  4. Try 7103 or 7101
  5. Check for a loose swaybar mounts. These almost always need to be re-tightened on new cars.
  6. Perhaps the headlight you have is: 996.631.154.01? (164.01 does not exist) I think an 01 designation is for from MY98 and has the orange under the headlight whereas the .20 would be a clear head light (both are Halogen headlights not Xenon).
  7. No you don't need to remove the engine. You will likely need to remove the rear wheels (unless you have access to a hoist).
  8. The buckle attaches to the seat frame and one side of the belt. The belt mechanism itself attaches to the chassis. Here are both of the seat bolts. 999.075.072.09 Fastening bolt (buckle) 803.019.811.B Fastening bolt (end of belt) 211.857.771 Washer for belt bolt
  9. You will have to look at the back of your CDR-23 - there should be "wired" plugs. What you can not use is the MOST fiber optic connector.
  10. :welcome: CDR-23 does not need a code - it communicates with the DME to get permission to operate. First, it maybe tough to find a Becker Traffic Pro. If you use it on your car it will not use the MOST system - it would need to be hardwired.
  11. This info is also in your owners manual under Capacities.
  12. Yes, if you take your time and make sure you have all the right parts for the options currently on your car. You will also need a dealer to turn on that option with a PIWIS tester.
  13. Have a look at TSB 6/06 9155 Telephone Module (I No. 666) (as of 2007) -- dated Oct 16, 2006.
  14. Cayenne V6 or Cayenne S or Cayenne Turbo?
  15. I am not sure what you mean - option 666 is the Telephone Module option.
  16. Any recent work (i.e spark plugs, etc.)?
  17. Does it turn over (starter runs?) but not start? If not, then start with the clutch interlock switch.
  18. Try 5381 or 5379
  19. Where do you live and what type of fuel are you using?
  20. I sent you your upgrade notice - you need to logout and then log back in.
  21. My car is MY1999. Perhaps Porsche feels that changing a remote key battery is now a "dealer serviceable item". :lol:
  22. The PCM Operators manual is free to download by any member. You can find it in the Porsche owners Manuals section. If you want the installation TSB - then you need to be a Contributing Member to view the TSB. Just click on the Donate link at the top left of any page to become a Contributing Member.
  23. Your car came with strut braces that are the same as the GT3 Cup Car race cars -- I guess I don't see a need for any additional bracing. JMHO.
