  1. That list is out of date. The current list is dated April 11, 2007.
  2. The B&M instructions (with pictures) are quite good (and not copyrighted). You can down them here.
  3. You should be ok - as long as the CEL is not flashing.
  4. Have a look at the battery thread here. I don't worry about weight - most of us could go faster if lost 10 or 20 pounds. ;)
  5. If the battery is 4 years old or older then it needs to be replaced anyway.
  6. The code can only be in the cluster with a PIWIS tester. So you need to find an independent shop with one or go to a dealer. There is no way around this.
  7. C4S stabilizer is supposed to be the same as the C2 Coupe with sport (M030) option (according to the Technik Book).
  8. If he orders it through he RennTech.org Amazon store we get a small percentage... ;) http://www.renntech.org/forums/index.php?a...amp;code=amazon
  9. You don't say the rest of the part number for the first bar so... Standard Front 996.343.701.09 -- 23.1 mm Sport Front 996.343.701.04 -- 23.6 mm
  10. All TSBs are available here to view by our Contributing Members.
  11. You are correct there was no Turbo S in 2001. The Turbo S did not come to market until late 2004. From the press release: As with any car get a CarFax, PPI, and a warranty if possible.
  12. I've got a 05/05 build date on a 987S M96/ 26 625 G8XXX Does that put me in the category of post new seal? Not sure how to interpret the "G". Yes, you have the new seal. G8xxx is the transmission code.
  13. You are going to have to get that from the dealer. Sometime they will let you fax them proof of ownership - so you can get it by telephone.
  14. The TSB has no harnesses on it - it has you remake the ground connections under the seat and replace the receptacles.
  15. http://www.renntech.org/forums/index.php?showtopic=185
  16. Chances are they sell the harnesses to DIY folks that don't have the pin removal tools they use in the TSB update.
  17. To know the exact cause of the "beep" zone open you will need the Durametric software, or a PST2 or a PIWIS tester. Any of those diagnostic tools will tell you exactly where the fault is.
  18. I think that would depend on the offset. The GT3 wheels should fit fine with GT3 size tires.
  19. http://www.renntech.org/forums/index.php?showtopic=38
  20. Loren
    mk1 flywheel
    The GT3 Mk1 and Mk2 both use the same dual-mass flywheel. The Cup Cars use a single mass flywheel.
  21. Probably not if it is a MY02 or newer. They extended the service interval. Well, I have an 04 and the dealer is insisting on changing plugs at my 30K service. They actually showed a porsche document stating that plugs are indeed to be changed at 30k Please ask them for a copy - I would like to see it. We get the same documentation the dealer gets - and ours says 60,000 (for MY01 and newer). Only the MY99 996 and 996 GT3 gets plugs at 30,000 miles.
  22. My point is that if your DTC codes are 360 and 361 then the OBD II fault codes are not P0172 and P0175.
  23. Don't you need to lock the car using the manual key and then unlock it to reset the alarm?
  24. There really isn't a point here (beyond what has been stated) - so I am going to close this thread.
