  1. View this tutorial How to Remove the Front Bumper Many folks have asked how to remove the front bumper to clean the radiators or replace the horns. So many that we thought it deserved it's own DIY here. We hope to add some pictures to this soon (since I keep forgetting to take them). Also see JeTexas excellent video DIY: Porsche 996 986 Front Bumper Removal Removing the Front Bumper 1. Remove the plastic rivet on the wheel liner (near the sidemarker). 2. Remove the center cover from the inside of the front trunk. Author Loren Category Carrera (996) - Maintenance Submitted 07/17/2007 06:08 PM Updated 07/06/2010 08:56 AM
  2. It is a bit more complicated. I'll try to put a DIY together in the next couple of days. You can find the new TT belt replacement here. Is the procedure the same for a 1998 2.5 986? Thanks, T The belt instructions are the same - you will need to remove the front engine cover (behind the seats) to get access on a Boxster
  3. Required? Maybe not, but the TSB does say to do it if the customer complains about it. You should talk to a manager and reference TSB 7/04 9662 Insufficient Range of Remote Control -- dated 8-13-2004. If needed you can quote this from the TSB: "If the customer complains that the range of the remote control continues to be insufficient (e.g., even after the remote control battery has been changed), the antenna lead should to be rerouted as described in work procedure (see page 2) in order to increase the reception strength of the antenna, thereby increasing the range of the remote control."
  4. What model and year of car? The previous owner could have changed the instrument cluster and not updated the mileage. In most states in the US that unlawful - unless they provide a document at the time of sale explaining the discrepancy. A dealer or shop with a PST2 or PIWIS tester should be able to verify information in the car's DME.
  5. Don't ask me why Tip and manuals get different mufflers - I do not know why but they do. 996.111.121.57 Right side muffler
  6. Almost no difference between a MY99 and MY00 C2. Egas and minor trim changes.
  7. I think you are going to have to look at the pads to determine whether they can be reused. If there are deep scores already then I wouldn't reuse them. With both new rotors and used (or new pads) you will have some bedding in to do. Maybe a little longer with used pads.
  8. Probably the least expensive solution would be somebody like Oklahoma Foreign. They have a good reputation for used parts.
  9. Yes, some twist and pull off very hard. I suggest lower the top and be careful you don't hit yourself when it comes off.
  10. Many of the option know have a setscrew. Lift the leather boot and look for a set screw -- if there is none then just twist and pull to remove.
  11. No screwdriver. On your year car there should be be two tabs that squeeze on each side of the connector.
  12. I do not know of a "blank" replacement - but a body shop might have an idea or two. If the clips and the base are installed correctly and not broken then the flaps should work like hinges.
  13. If those numbers don't work then you will need to contact a dealer or Becker. As I recall Becker charges $35 so you might want to try your dealer first.
  14. Loren
    mk1 flywheel
    There is only one PET and it is updated monthly - to all dealers worldwide.
  15. To the right of the battery, on the firewall, is a rubber plug. Cut an X in it and pass the wires through.
  16. The GPS antenna is Porsche part number 996.642.206.00. I show a US MSRP of 93.48 USD. Make sure you get the cable too. You can probably get a CD on eBay or from NAVTEQ. The security code will have to come from Becker. You will be asked for the serial number of the unit and also likely for some proof of ownership.
  17. It sounds like you have a wire in the wrong place. Or, the wrong relay in the wrong position.
  18. Have you checked fuses B9 and E9?
  19. Perhaps you are confusing the bumper pieces with the underbody covers?
