  1. Sounds like the older style radiator where both radiators are the same part number and they use a sealing cap for the second opening. The production change on those happened in July of 2001 - they were made side specific after that. Unless some dealer has old stock on hand I doubt you will be able to find a new plug. In that case you will likely have to replace the radiator.
  2. If you can PM me the VIN I can get the original options for that car (dealers charge for this). Only a dealer can get you a Porsche dealership service history - and they may need permission of the current owner to do that.
  3. Do a search for: +cluster +bulb That will get several descriptions.
  4. There are two sensors on each engine bank. One before the cat and one after. If your car has 60,000 miles or more I would not waste timing trying to clean the sensor - since it has likely reached it's life expectancy. My code interpretations come from Porsche's OBD II manual.
  5. P2096 Signal Delay Time for Oxygen Sensor Ageing - Above Limit Possible fault cause: - Oxygen sensor I would wait and see if before replacing the sensor.
  6. You can download the MY03 TT Owner's Manual here.
  7. Proper offsets are listed in your Owners Manual. Those will likely work.
  8. Of course you folks know all the Cayenne Maintenance Checklists are here on the site? http://www.renntech.org/forums/index.php?a...=maint_menu_cay
  9. Next time it would be very helpful if you please give us the country. The factory installed options for that VIN (only) are: I029 I211 I242 I697 IX46 tiptronic selector lever in aluminium/leather IX54 stainless steel tailpipes IX71 instrument dial painted/aluminium look finish IX98 handbrake lever in aluminium/leather IXCC IXCB IXCA IXJ4 leather cover for ignition lock surround IXSA painted sports seat backrest IXSC porsche crest embossed in headrest IXTR IXV1 defroster trim in leather M061 version for great britain M071 eu country version M130 control and indications in english lettering M197 stronger battery M249 tiptronic transmission M265 automatic anti-dazzle interior mirror with rain sensor M266 automatic anti-dazzle door mirror M271 door mirror -aspherical- driver's side, electrically adjustable and heatable M274 vanity mirror illuminated M273 door mirrors, electrically adjustable and heatable M288 headlamp washer M339 all-wheel drive M335 automatic seat belt, 3-point, rear M342 seat heating system, left/right seat M376 sports seat, backrest shell, right M375 sports seat, backrest shell, left M410 18-inch turbo 2 wheel M425 rear window wiper M424 cd compartment M436 3-spoke airbag steering wheel M432 steering wheel with tiptronic control M441 radio preparation M466 rear foglamp, right M476 porsche stability management (psm) M492 headlamps for left-hand traffic M539 mechanical seat-height adjustment, left M536 alarm siren and tilt sensor M534 theft security system M540 mechanical seat-height adjustment, right M563 side airbag M566 front fog lights, white M567 windscreen tinted, upper part darker coloured M562 airbag, driver's side and front passenger's side M573 air conditioner M571 activated charcoal filter M581 center console, front M602 raised stop lamp M601 xenon lighting system M620 electronic accelerator M635 parking assistent M657 power assisted steering M650 electrical sliding roof M659 on-board computer M651 electric window opener M661 stricter emission-control concept M685 rear seats, split M680 -my 01 digital sound package my 02- sound system bose analog M692 cd autochanger "porsche " M936 seat covers, rear, leather M983 seat covers, front, leather M981 leather equipment without seat covers
  10. ...and don't break or lose the paper gasket that goes between the idle control valve and the throttle body.
  11. It's probably your cable. You should buy the correct cable from http://www.obd-2.com.
  12. Try 2835 or 2837
  13. Carburator cleaner , fuel injector cleaner, etc. A spray can version will be easier to use. Most of these contain primarily lacquer thinner so keep them away from any painted surfaces.
  14. Yes there are likely two issues. One is that the cluster needs to be the same model/version - the clusters change in MY03 Boxster and also Tipronic clusters are different than manual transmission clusters. Second the cluster should be programmed for the options in your car like location, temperature (F or C), specific car options etc., etc. Any cluster with over 52 miles can not have the mileage changed by a dealer only a certified instrument repair shop (like Palo Alto Speedometer can do that. It would be good if you would put your "real" location in so we could suggest someone to program your cluster for you.
  15. http://www.renntech.org/forums/index.php?s...ost&p=14785
  16. 996.613.535.00 is the correct part number. I have found parts with Mercedes logs, BMW logo, and VW logos... and I think the climate control has an Audi logo. Now we know why Porsche is profitable. :lol:
  17. Try 6885 or 6887
  18. Not unless you are really really thin. Most folks find it easiest to remove the rear wheels to remove the mufflers. That way when you remove the 3 bolts on the hanger bracket (and the sleeve on the cats) the muffler just rotates down and out.
  19. :lol: :lol: :lol: :lol: :lol: I never thought of that - good one Chuck!
  20. I just back the rear tires up on 2 set of 2 x10 boards (so roughly 4 inches) and that is enough room and still keeps the car pretty level. If you wanted absolute level then put 2 sets of 2 x 10's under the front tires too.
  21. I don't think that would hurt but Porsche does not specify that.
  22. Take it to a body shop the works on Porsches. They can tell you. Prices will vary so get 2 or 3 quotes.
