  1. The problem is that you a a MOST (fiber optic) linked sound system in your car. To replace it requires adding wiring for a traditional sound system.
  2. There are 24 pages of the wiring diagram for that model year - can you narrow down what circuit it is in? (What fuse blows?)
  3. Yes, you are correct - I should have stated that more clearly. It's not pressure it is vacuum. My bad...
  4. Try 8522 or 8524 Do a search here there have been a couple of folks that have bought the display on eBay and then made the modification for them to work.
  5. Yes, easier if you remove the headlight first they just snap in and out.
  6. Some shops have a gauge that replaces the oil filler cap - they use that to see the crankcase pressure. High crankcase pressure is usually a sure sign of AOS or bellows failure.
  7. Try 8534 or 8536
  8. Sorry, I don't think Porsche sells it separately - I don't find it in the parts list.
  9. They should be marked on the wheel near the valve stem.
  10. I seem to recall that it takes a few minutes to re-calibrate and it may need the disk for that too.
  11. As far as I know the only place you can get a NAV code is from a dealer.
  12. Well, another option is the Durametric Software. A 3 car use license and cable are $247. Very useful if you ever need to reset the airbag light or have a CEL.
  13. You need to check Sunset Imports (Porsche Parts at Dealer Cost - link at the top of the page) price on a remote - they are under $100.
  14. Where are you located? Perhaps a member with the Durametric Software or a PST2 will reset it for you - for free.
  15. Remote windows and top are already a feature of the Porsche system - but they were not offered in the US. As I recall you need a 2 or 3 button key and then reprogram the alarm/central locking controller to a European country. You will need a shop with a PST2 or PIWIS tester to do the reprogramming. Porsche had sold schematics on their tech website in the past (for $110 each) - but I now see that feature is gone from their site.
  16. :welcome: Yes, the shocks and springs are different due top the weight and weight distribution differences. There are also differences for a 6 speed vs. a Tiptronic - for the same reasons.
  17. This thread is now closed.
  18. Why? If your car is overheating it is not because the fans are running too slow. Did you know Cup Cars have no fans?
  19. Porsche Sport Exhaust mufflers for a MY04 - on C4S. If you plan to use these on a narrow body car you will likely need to swap the hangers from your old mufflers (so they will line up properly).
  20. Any shop with a PST2 or PIWIS tester and your VIN's IPAS code can code a key for you. Your IPAS code must be obtained by the car owner from a Porsche dealer/OPC.
  21. Please keep it friendly (and helpful) here folks...
  22. It works fine for me.... "With the ignition on, hold the adjustment button (the one that looks like a clock) to the left for about 4 seconds."
  23. The MY03 Owners Manual here should be pretty close. The answer is on page 71.
