  1. RoW alarms are different than US/Canada alarms. Where are you located davej_anderson?
  2. Try 0069 or 0071
  3. Both of those tools are for older (and some pre-OBD II) cars. The Durametric Software and Porsche tools I mentioned are for OBD II cars. I really don't think you can compare the two. The Bosch hammer works well on many of the pre-OBD II cars but we were not discussing them in this thread.
  4. Durametric is OK for reading and/or clearing emission faults. It lacks the diagnosis of components on the Porshe to test the part on the car before removing. The is the true backbone of an diagnostic tool---which Duramertic lacks. Just my 2cents. It is also $18,000 less expensive that a Porsche PIWIS or $3,600 less expensive than a used PST2.
  5. 986.504.912.00 (Porsche calls it) Hinge
  6. Left or right side?
  7. Try your local PCA region for recommendations of good independent Porsche repair shops.
  8. A 996 Carrera and a 996 TT use different base engines.
  9. Cayenne Bulb Chart
  10. Hmm... I wonder if you have a bad light switch?
  11. The Boxster engine is the same as the Carrera (except it faces the other direction). Any of the Carrera DIY oil change articles will work for a Boxster too. https://www.renntech.org/forums/index.php?showtopic=7055 I think the air filer has been covered elsewhere in the Boxster forums - try doing a search.
  12. Get the Porsche parts they are not that expensive and they come with high temperature adhesive backs to hold them in place. Make sure the sure the surface is claen and dry when you install them.
  13. 000.044.500.07 RoW Mo303 kit for MY99 C2, coupe, 6-speed.
  14. A special thank you to new member Dan (carguy212) for uploading a bunch of current, recent and historic Porsche Sales Brochures. For now these are in the Public Downloads section - but we will be moving them to a "Brochures" section in the near future. 1970s PorscheAir.pdf 1972 911.pdf 1972 914.pdf 1973 914.pdf 1974 914.pdf 1975 914.pdf 1976 912e.pdf 2006 911.pdf 2006 boxster.pdf 2006 cayenne.pdf 2006 cayman.pdf 2007 911_997_turbo_us.pdf 2007 911_targa_gb.pdf 2007 Boxster.pdf 2007 Cayenne.pdf 2007 Cayman.pdf Thanks again carguy212! :clapping:
  15. IMHO... just enough that it does not leak (they are pretty easy to twist off).
  16. C2 or C4? - the fuel tanks are very different. Have you checked the fuses? P0453 Tank Pressure Sensor - Short to B+ Check wiring from pressure sensor to DME control module for short to B+. 1. Connect special tool 9616 to wiring harness (DME control module connector). 2. Remove connector of pressure sensor. 3. Connect voltmeter to special tool 9616, pin 72, and ground. Display: 0 V If battery voltage is displayed, check wiring harness for chafing and pinching damage. The spoiler light is normal - it does not go out until the car moves (forward or reverse).
  17. For Mobil 1 0W-40 I think I paid $5.49/quart at Autozone (by the case) last time. I don't have a problem with Mobil 1, Castrol, or Pennzoil/Quaker State synthetics - they are all good oils.
  18. Porsche's method to bleed the ABS is to hookup a PST2 or PIWIS tester and use a built-in function that starts the ABS pump during bleeding.
  19. Probably Royal Purple Motor Oil. http://www.royalpurple.com/prodsa/auto.html Sold by: Pep Boys Kragen Auto Parts NAPA Auto Parts
  20. Perhaps someone changed pads without putting on new vibration dampers?
  21. :welcome:
  22. I haven't seen the "scratchers" on cars in years. Your Porsche has pad sensors. These are essentially a wire covered in plastic - when the insulation wears through the action of the pads causes the wire to break -- it turn a light on in your instrument cluster. Much better than the old scratchers.
  23. 987 to 986 = ok. 997 to 986 = not ok. The front might fit but when you install them check the front for clearance issues and install 5mm spacers if required. The rears are too wide and have the wrong offset.
  24. http://www.renntech.org/forums/index.php?showtopic=7067
