  1. Yes and no... If it is a bad sensor probably not. If it is a stuck thermostat then possibly.
  2. TC was only MY99 so you don't have it. I doubt Porsche would carry both parts if either would work. Maybe Tool Pants remembers what those connect to - I don't off the top of my head. Maybe seat heaters?
  3. Likely that you either you have a bad sensor or your thermostat is stuck open all the time.
  4. Do you have PSM? MY99 did not - it had TC.
  5. Not according to the parts list. MY00 and 01 are interchangeable but not MY99. I do not know the reason why.
  6. PM me your VIN and I'll see what I can do.
  7. http://www.renntech.org/forums/index.php?s...ost&p=29500
  8. DO NOT use a pickle fork. Use the tool described here.
  9. Take them out clean the grooves and then re-install them. Do a search I posted the instruction a while back.
  10. That part has been changed (design change) so you will likely have to replace both. You will need the ball joint tool described elsewhere here and of course you will need an alignment for the rear of the car.
  11. Early is up to the new style cluster which was MY02 in Carrera's and MY03 in Boxster's (as I recall).
  12. The Retail Price Search feature (for our Contributing Members) has been updated to reflect September 2007 pricing for the US (only). We try and update this on a monthly basis as the price lists come available to us. For September 2007 the price lists support - US: 259,124 parts Canada: 209,209 parts (December 2006)
  13. All 986 Boxsters and all 996 Carreras can have the OBC "turned on". On the early cars it is just one program change (in the cluster) - on the later cars it requires two changes (one in the cluster and one in the DME).
  14. It is exactly the same for a MY01 and older Boxster and Carrera. You need to find a new shop.
  15. Yes, in about 2 minutes with a PST2 or PIWIS.
  16. It just means you have one or more options from the Exclusive option list.
  17. Try 999.590.046.40 disc cam
  18. 999.702.221.40 grommet -- MSRP $2.40
  19. I am not sure this a DIY project since the TSB says that you need to replace the retaining frame and replace the lift mechanism of the glass sliding cover. It also says that mixing part from the new kit and the old frame are not allowed. Welcome to the site - as you may or may not know all TSBs are available here to Contributing Members. We have a minimum of a $25 (US) donation and no maximum. Contributing Members can view TSBs online, use the Retail Price Search feature, and access the Contributors Only Forum. They can send attachments with PMs, image storage limits are raised for all Contributing Members, RennTech.org email addresses are available and a personal Blog. Contributions help defer the cost of running this site and providing this information to you. No one has to contribute but many members do. Without contributions this site would either have to go subscription or cease to exist.
  20. I think you worry too much ;) IN the new version you just replace the whole housing - 4 nuts.
  21. TSB 4/05 3408 Short Shift Kit Installation Instructions - which you have access to.
  22. Maybe a leaky fuel injector. If it were oil the pipe would have been greasy.
  23. That would say that the mixture on cylinders 1-3 is too rich (and the DME can not lean it enough) and your misfires and your O2 sensor on the cylinder 4-6 side is shorted (or reading a very high voltage). I would find a shop with some good OBD II software and have them read the MAF air flow and TRA\FRA values so you can really see what is going on.
