  1. Can you pick out the item number here?
  2. As long as you have the correct size of Security Torx (the one with the oin in the middle).
  3. Item 7 on the front of the air intake tube.
  4. I would start by having your battery load tested.
  5. L84S = Arena Red Pearl (97-99)
  6. Yup. I post more and directions early next week.
  7. 996.631.042.00 Right mounting -- MSRP $89.09 Try the folks at Sunset Imports (Porsche Parts at Dealer Cost) for a much better price.
  8. The schematic says it is clipped to the heater box on the driver side.
  9. :welcome:
  10. 87 octane? - your owners manual says 93 (or at least 91). I think you need to find someone that can look at your actual air flow, FRA TRA, and O2 sensor voltages.
  11. I agree with Too Pants - looks like LoJack.
  12. The only things between the fuse and the window motor are the switches and the relay. If the switches are not shorted or the relay is not bad then it has to be one of the motors.
  13. Maybe and maybe not. I've heard a little bit of seepage is normal. According to tech friend - Porsche actually sent a memo out telling them they were not going to honor warranty for changing water pumps that had the white crusty buildup and did not have broken impellers or cracked housings.
  14. The pump is in the left front fender. Either a hose has come off, or the pump is not working, or the tank is cracked and leaking.
  15. The phone prep goes to two fuse on the right fuse box.
  16. Look for a phone prep plug (similar to the 986/996) under the passenger seat or in the center console - depending on your options.
  17. This is likely the switch in the door handle. Please do a search as this has been covered here several times.
  18. 50 mm front and 45 mm rear for stock 18" wheels. 50 mm front and 63 mm rear are allowed if a 17 mm spacer is used (18" wheels).
  19. You likely need a firmware update (done by your Porsche dealer).
  20. Sorry - $274.55 is the correct MSRP Price list should be fixed now.
  21. Sept 2007 price came in a different format - let me try and fix it so the prices are correct again.
  22. Please do a search - that has been covered many many times...
  23. Replacing the Coolant Reservoir on a MY99 996
  24. Durametric can not do this at this time. Where in California are you located?
