  1. He must not know how to isolate an electrical fault... You start by putting an amp meter is series and measure the draw (ignition off - no key). Then remove one fuse at a time and see which circuit affects the draw. Once you have found the circuit you then isolate which component is the problem.
  2. 19 mm I use a deep socket with black electrical tape wrapped around it so that it does not scratch.
  3. That part number is for a MY03 or newer car.
  4. What part number does your new filter say?
  5. Try 4953 or 4951
  6. Try 0989 or 0987
  7. Try 4240 or 4239
  8. 2. Left front wheel liner 996.504.203.06. You will also likely want to buy a few spare plastic rivets since they sometime break in removal - 999.507.497.40 Plastic Rivet 1. Here is the parts list for the roof liner (for the convertible top). Perhaps you can tell what you need from it. my03_roofliner.pdf
  9. Please read some of the other posts here -- sometimes my code program does not work (or people give me the wrong serial number). In either case you need to contact a dealer or Becker. Becker charges for the service - some dealers charge also.
  10. http://www.renntech.org/forums/index.php?s...ost&p=23363 http://www.renntech.org/forums/index.php?showtopic=15494
  11. Try 8761 or 8759
  12. Well, the parts list does not show it so I guess maybe they removed it (not needed) or... I'm stumped. ;)
  13. Lift the wire clasp on the top of the bleeder valve.
  14. Sorry, to be dense here but I don't see it in the picture.
  15. Those are not bolts they are studs that hold the shield on. Or do you need the heatshield? If so, please specify left or right.
  16. Try 4667 or 4665
  17. Sounds like the condensation tube for the AC is not poking down to the outside of the car.
  18. For those of you that have not heard... John Dunkle posted the following on Oct 31, 2007. "Today, Rennlist.com was acquired by Internet Brands, Inc.. Internet Brands owns and operates many of the most pervasive on-line automotive enthusiast communities found on the Internet today. They include sites such as CarsDirect.com, CorvetteForum.com, Audiworld.com, MBWorld.org, etc." We here at RennTech.org wish to congratulate John and Jen on the sale and wish them the very best in their future endeavors. Truly they paved the way for all other Porsche forums that followed. More
  19. Last time I checked the Owner Manual was about $20-$25 at Sunset Imports (Porsche Parts at Dealer Cost). For MY96 US car order WKD.993.021.96
  20. Porsche content here please....
  21. Only a dealer can look up that information.
  22. Loren, this is also true for the 987 Boxster/Cayman right? On a 9x7 series car the fuel filter is incorporated into the fuel pump itself. Under normal use it does not need to be changed.
  23. 955.620.841.00 MY06 fuel filter Please realize that you need to drain the fuel from the tank, a special tool to remove the insert to the tank for the filter. The fuel filter is under the left tank cap (the fuel regulator is under the right tank cap). Perhaps this something best done by a trained shop with the proper tools?
  24. :welcome: The Cayenne fuel filter is incorporated into the fuel tank and under normal use does not require changing.
  25. Not sure what you mean... Here is the diagram or do you mean muffler heatshields?
