  1. So, if all the gears are the same. Is TechArt just running that 997 way over factory redline? How else could it be that much faster on the top end? I suspect TechArt has done much more than an X50 package.
  2. X50 is an engine upgrade/modification only. It has nothing to do with the suspension or transmission.
  3. Perhaps what you do not realize is that Sunset has little choice for local purchases. There are competing dealers in their local area and if they give too big a discount those dealers complain to PCNA. PCNA then complains to Sunset. When you are part of a manufacturers dealer network you have to play by the manufacturers rules (and Porsche has a ton of them). The reason people outside of their local area can get a discount is because that is "any body's market" (as defines by Porsche AG).
  4. Model and year of your car please? ... and US or ROW?
  5. :welcome:
  6. 993.615.115.00 about $18 retail - check with Sunset Imports (Porsche Parts at Dealer Cost) for a better price.
  7. One of the connections must be bad. You can jumper each one until the light goes out to find out which one(s) are the problem.
  8. I think you only need that for keys or alarms not DME programming. If you can provided proof of ownership there is no reason they should not supply you with it.
  9. Then one of your sensors is not likely completely plugged in.
  10. Just a word to the wise - there are some "electronic" options on the newer car that Porsche has locked down with access codes. So anyone with a PIWIS may not be able to just turn on a function. Instead they would need to contact Porsche (showing proof of payment) and then getting the access code to turn the function on. I know this is true on the Cayenne Compass option.
  11. If you wan the Porsche one - it is in a TSB. Tool Pants (et al) did a DVD that covers the whole thing too. http://www.renntech.org/forums/index.php?s...ost&p=18034
  12. Porsche Battery - $194.39 (retail) Autozone Duralast - about $69. http://www.renntech.org/forums/index.php?s...ost&p=14446
  13. Please do a search here - it's been covered many times.
  14. If it were my car I would start by removing and cleaning the throttle body. I've seen several egas Boxsters that idle poorly and 98.0% of the time it has been a dirty throttle body.
  15. Is this a US car? Where are you located?
  16. Not really - like the quote says that pump runs for a max of 179 seconds (just under 3 minutes). These engines are already putting outs lots of HP/liter as it is. (IMHO) With late model Porsche's there is not much to be gained with mods. If you want a lot more power you move up to a GT3 or TT. The TT responds pretty well to specific mods - but then you have to ask yourself if you really need 750-800 HP (and can handle it).
  17. More than you likely want to know... "Auxiliary Air Pump To reduce pollutants contained in the exhaust gas during the warm-up phase and to achieve the emission limits of the roll test in the USA, USA vehicles have a secondary air system. For this reason, an electric air pump has been mounted on the left-hand side of the engine compartment. This pump is activated by the DME control unit and blows the additional air through air ducts to the discharge valve. A pneumatic switching valve which is closed when the secondary air system is inactive thus preventing the flow of additional air is installed between the air pump and the discharge valve. Functioning If the engine is started in a temperature range between minus 10.5° C and plus 45° C, the secondary air system is activated for a period of time dependent on the start temperature (min. 50 seconds, max. 179 seconds). The secondary air system is only activated if the following engine-related operating conditions apply: - Engine load (TL) between 0.7 ms/rev, and 4.7 ms/rev. - Air mass (ML) not greater than 300 kg/h - Engine speed between 680 rpm and 2,800 rpm - Altitude adaptation factor greater than 0.76 corresponding to less than 2,400 meters above sea level."
  18. On a MY02 and newer cluster there 6 wires to the OBC not 5. Pin A1 (Brown/Blue) off the stalk needs to go to component ground.
  19. Bill, Just to be clear - Anne will need to find a (in her case) MY02 or newer C2 cab so that I can perform the programming. Since your procedure includes "3. Open (or close) the top slightly so the top cover is out of the closed position," - it can't be programmed using a coupe. Correct?
  20. On the left is the CD Changer with 6 pins. A1 = 1 A2 = 2 On the DVD Player - would be easier if you had the connector (as it is likely numbered). A1 should be ground and chassis ground - so if you take an ohm meter there should be zero resistance between pin A1 and the chassis. If I had a first guess I would guess the top right pin in your pic is A1. A2 should be the next pin in the A1. On the DVD Player only A1, A2, and A5 are used. A3 and A4 are for diagnosis so they are not normally connected. And A6, A7, and A8 are not connected.
  21. That could be a real challenge. The 997 NAV and CDC-4 communicate with fiber optic cables (MOST network). Did you salvage those too? On the DVD Player A1 is ground and A2 is power. You will need the fiber optic cables off B1 and B2 also. On the CDC-4 A2 is ground and A1 is power. B! and B2 are fiber optic again. With that said I have no idea if they will function onside of the car over the network or if they still need at least one network controller. Let us know how you make out...
  22. The Durametric Tool does some special things with Porsches that factory tools costing thousands of dollars can do. So I don't thing you can compare that to a more generic ISO tool. If you need the features of the Durametric software then you might want to consider it plus the Car Code OBD-2 Vehicle Explorer Scan Tool that I reviewed here.
  23. Sorry, guys the 996 wiring is not even close to a 997. 997 series cars have easily 10 times more CAN (network) and CAN controllers - that all interact. Apples and Oranges really.
  24. A few pics from yesterdays Work Cars Day... Can this be a Boxster cluster? (project 1) Done a few of these too... Once again proof of how easy these cars are to work on... Back to that cluster... (installing a 996 cluster in a Boxster) Adding one wire from the cluster to the engine compartment oil pressure sending unit Where the new (996) sending unit goes... Installed and wires connected MY2001 Boxster with a fully functional 996 cluster and a B&M short shifter. Special thanks to Anne (she did most of the work - including providing lunch) and Rich (who took most of the pics). Anne is pretty good at this stuff I think she could give Eileen in the Bay Area a good contest :lol:
