  1. Have you checked fuse E1 and E5? I think there might also be a fuse on the back of the unit too.
  2. http://www.renntech.org/forums/index.php?s...ost&p=14785
  3. Read my Blog for comments on dyno runs. There are a lot of things (variables) that can change that will increase or decrease HP - even on an unchanged engine
  4. The ParkAssistent system and the headlights are not connected. Are you sure the battery is being charged? Your voltmeter should show around 13-14.5 volts when the engine is running.
  5. "Market launch of the new Porsche Boxster RS 60 Spyder is starting worldwide in March 2008. Including 19 per cent VAT and country-specific requirements, the retail price in Germany is Euro 63,873, the base price Euro 53,500." It is likely a couple of months away...
  6. First thing to look at is the cables and the linkage under the car.
  7. Try 0825 or 0823
  8. :welcome: P0446 EVAP Canister Shutoff Valve (Function) - Below Lower Limit Potential causes: - Purge air line blocked. - Flow resistance of EVAP canister too high. This says you are failing the fuel tank (sealing) test. Look for a loose gas cap (or bad o-ring seal) or one of the causes above.
  9. 1 ea 900 123 106 30 Aluminum Sealing Ring Is this the same part that would be used on a MY06 2.7l Boxster? Yes, it is the same part.
  10. This is very old and has been posted before - so I will close this thread.
  11. Oil Temperature is a function of the Oil Temperature/Oil Level Sensor. It is read by the DME (all models that I am aware of). So, theoretically adding an oil temperature gauge should be pretty straight forward. MY03 shown below
  12. I don't think the Cab sun visors pivot either (perhaps a Cab owner can verify). I think it is a convertible thing - perhaps Porsche thinks they will jam in top? The 996 Coupe (at least my MY99) does pivot. If that is the case I wonder if you could put the Coupe sun visors on a Cab or Boxster?
  13. Sorry, I have never seen a PSE (only install) produce any HP gain.
  14. The CEL does go out for several "drive cycles". Give it a couple of days and if it does not go out then get your fault codes read at an Autozone (or other parts store that will read them for free).
  15. He needs to be careful - in California it is illegal to tint the front or front side windows.
  16. Unless there is leather or carbon or wood in the car that is the only black one.
  17. There really isn't much to the ParkAssistent - just a controller box and the sensors. I would start by checking fuse B10 (second row - first fuse from the right).
  18. Did you see the Becker after market connector diagram here?
  19. You need to have your alarm controller read with the Durametric Software, a PST2, or a PIWIS tester to see what the fault codes are. Where are you located? Perhaps another member with one of these tools will help you out...
  20. Certainly air could be introduced if the pedal was moved during the tank replacement. But, it is highly unlikely that air has gotten into the ABS system. If you bleed the brakes as normally done I think you should be fine - you likely will want to bleed the clutch also as it is on the same circuit. If you bleed the brakes and the pedal is squishy or soft then it is likely air in the system.
  21. RFM is correct - my bad I was thinking of the 996 Carrera hoses.
  22. When you fit the new hose use new screw-type hose clamps. Those spring clamps are barely good enough for one use and certainly not two.
  23. The pollen cover is one piece (item 1). 996.572.019.02 The battery cover (item 4) is: 996.572.567.01.01C If you don't have the hold downs then you will also need (2 each): 999.590.045.40 screw plug 999.590.046.40 disc cam
  24. The controller is under the dash on the drivers side.
  25. It depends - if it is a lower hose you might get lucky and just need to remove the liner. If it is an upper hose then you will need to remove the front bumper and likely loosen the radiator mounts to get to the (upper) hose.
