  1. The list price for MY99 Owners Manual (WKD 996 120 99) is only $20. I think the folks at Sunset Imports (Porsche Parts at Dealer Cost) can even do better than that.
  2. The following is Porsche's test spec for the vehicle battery (from TSB 4/02 2706 Battery - Maintenance Checklist -- dated 3-7-03)
  3. Yes, there is no ICV on egas cars. Idle control is done through minute movements of the throttle butterfly.
  4. 5 years - consider yourself lucky. Very few batteries last 5 years. Start to plan your next purchase at 4 years.
  5. In the US you usually purchase an extended warranty that starts when the manufacturers warranty ends.
  6. Error codes over 100 indicate a faulty control module and cannot be reset even with a PIWIS or PST2.
  7. Measure the voltage across the battery (+ and - ) terminals at rest (engine not running) and while the engine is running (with an accurate volt meter).
  8. Try 8951 or 8949
  9. Sorry, I do not understand your question (or statement)
  10. When the car is running it should be about 14 volts at the battery. At rest it should be at least 12 volts. If the battery and charging circuit is good then I think you need a new triggering unit.
  11. What is the fault code? and where are you located?
  12. Fault 1 Possible cause of fault - Faulty fuse - Airbag warning light faulty (no bulb, cannot be exchanged) - Short circuit to B+/ground or open circuit in the wiring between the instrument cluster and the airbag triggering unit Fault 3 Possible cause of fault - Low battery positive voltage (this is fairly common if the battery has been recently disconnected). Fault 195 Fault codes above 100 Possible cause of fault - Airbag triggering unit faulty Check the voltage supply (battery and charging circuit) before replacing any control module.
  13. What is the fault code(s)?
  14. P0154 Oxygen Sensor Ahead of TWC, Bank 2 – Interruption of Signal P1128 Oxygen Sensing Adaptation, Idle Range, Bank 1 – Above Limit P1130 Oxygen Sensing Adaptation, Idle Range, Bank 2 – Above Limit P0300 Misfire Detection (Sum Total) P0301 Misfiring, Cylinder 1 P0302 Misfiring, Cylinder 2 P0303 Misfiring, Cylinder 3 These codes say your fuel mixture is too rich for the DME to control - to the point of misfires. Since it is only on one side of the engine I think you should start looking for leaks and/or an air/oil separator problem. Unless someone just changed the spark plugs (and cracked the coils) there is no reason for 3 plugs to all misfire at the same time other than a leak on that side of the engine.
  15. I think you want D17 on the DME (TN-signal) - that is what was used for all the older cars.
  16. http://www.renntech.org/forums/index.php?s...post&p=1991 He has lots of pics in the link at the bottom of his post. (http://gallery.rennlist.com/cayennegallery...ing-Air-Filters)
  17. Most often it is the trigging spring in the steering wheel. Do you know the fault code number?
  18. I am sorry about your misfortune. Had you purchased the car in the state of California they would have been required to make it pass smog. "Section 24007 (B)(2) of the Vehicle Code states it is the responsibility of the seller to provide a valid smog certificate at the time of delivery of the vehicle. There is no provision in the law to sell a vehicle "as is."" "24007. (a) (1) No dealer or person holding a retail seller's permit shall sell a new or used vehicle that is not in compliance with this code and departmental regulations adopted pursuant to this code, unless the vehicle is sold to another dealer, sold for the purpose of being legally wrecked or dismantled, or sold exclusively for off-highway use." " (B) (1) Except as provided in Section 24007.5, no person shall sell, or offer or deliver for sale, to the ultimate purchaser, or to any subsequent purchaser a new or used motor vehicle, as those terms are defined in Chapter 2 (commencing with Section 39010) of Part 1 of Division 26 of the Health and Safety Code, subject to Part 5 (commencing with Section 43000) of that Division 26 which is not in compliance with that part and the rules and regulations of the State Air Resources Board, unless the vehicle is sold to a dealer or sold for the purpose of being legally wrecked or dismantled. (2) Prior to or at the time of delivery for sale, the seller shall provide the purchaser a valid certificate of compliance or certificate of noncompliance, as appropriate, issued in accordance with Section 44015 of the Health and Safety Code."
  19. I went over to Hergesheimer and they used their big computer (PIWIS..?) to read the codes, airbag light was there... since it wasnt the seatbelt error for the airbag they couldnt reset it for liability issues... although they could have with their tool. With that said, someone is coming and checking my car out on Sunday to buy it and my durametric doesnt clear this airbag code! Anyone know what I can do??? Anyone have one of those PIWIS or PST2 computers in southern california.. Burnout the bulb?? If they looked at it with a PIWIS or PST2 then they saw the fault code. What is the fault code(s)?
  20. hhmmm no... do you know if there is an option cross-reference online somewhere ?? The MY05 Cayenne order guide (with all the available options) is here.
  21. On a 996 C2 (narrow body) 50 or 52 mm offset will fit for the front and 63 or 65 mm will fit the rear just fine.
  22. Yes, if you disconnect the battery for 5 minutes or more the DME will go back to it's basic program. It will then re-learn to your driving style. You won't see a huge difference but you will see some. The control unit for the Tiptronic does the same - so I guess Tiptronic drivers might see the most change.
