  1. Item7? If so, 996.803.541.00.01C Cover (black)
  2. Try 2568 or 2566 Neither code worked. Any other suggestions. I confirmed the serial # Sorry, then you will need to contact your dealer or Becker.
  3. Did you check your Owners Manual?
  4. (All) TSBs are available here to all Contributing Members.
  5. Just an FYI - most of these "owners" books are pretty reasonably priced by Porsche. For instance most Owners Manuals are $20 or less (MSRP). And places like Sunset Imports (Porsche Parts at Dealer Cost) are even less.
  6. Remove the rear wheel and the heat shield and there they are.
  7. :welcome: You will find the headlight adjustment procedure in your Owners Manual.
  8. Read through this thread - "Wait" is explained as is what if they don't work.
  9. From the MY02 Carrera Technik Service book (available here to Contributing Members) Porsche A96/50 Tiptronic transmission manufactured by DaimlerChrysler (Mercedes). "In contrast to previous transmissions, the new Tiptronic control unit has 250 different shift maps instead of just five. The maps permit virtually step-less adaptation. "
  10. Try 1946 or 1944
  11. If it does not go away when warmed up then you should have your dealer check it out - while you are still under warranty.
  12. Model and year of car? Mileage? Does it only happen when the engine is cold?
  13. Thank you! :thumbup:
  14. Depends on what you are looking for... Here is there other option from the air horns. http://www.griotsgarage.com/product/car+ac...vals&page=1
  15. Some of the after market flash programs do great things on Turbo's but I have yet to see one produce much on a normally aspirated (non-turbo) car.
  16. The MY05 Order Guide for Canada is here but I doubt it will be any different.
  17. C00 - Germany (country) version None of the other (of those Exclusive option codes) show up on any of my lists. You would need to get a VIN report or Certificate of Authenticity from Porsche to perhaps get some information on those codes.
  18. Please try using our Search feature - it really works well.... GT3 Bumper Screen Install, DIY
  19. Porsche does not supply schematics for the inside of the (Bosch) DME - only the inputs and outputs of the box. A chip does not have to be changed to alter the programming. There are several after market companies that re-program the existing DME. Event thought they call ot "chipping" very few actually replace a chip they just re-program the ROM.
  20. Thank you. You are very welcome. I am glad the board has helped - after all we are a family (of Porsche owners) and there are many here that are more than willing to help when they can. Happy Holidays to all!
  21. Your local Porsche dealer or Sunset Imports (Porsche Parts at Dealer Cost).
  22. On older cars (pre MY2003 MOST cars) there was a radio security code that was required to use the radio. This was intended (I think) as a deterrent to keep people from stealing the car radio. CDR-23 is a MOST radio and has its code stored in the DME so if the power fails you do not lose the code. If the radio in a MOPT system car is changed (to another Porsche CDR-23) then the new radip's code need to be entered into the DME (with a PIWIS or PST2 tester).
  23. No adjustment - if it is bad then it should be replaced.
  24. Please tell us what model and year car? US or RoW?
  25. If the Boxster S engine is from a MY03 or newer Boxster then it has VarioCam Plus and would require a DME change and you may need to use the fuel lines and intake from your old engine (due to changed in the fuel circuit (returnless fuel system)).
