  1. I would start with an under car inspection. Look for loose or badly worn swaybar bushings, muffler heat shields rubbing, and spin the wheels and listen for noises.
  2. Two possibilities come to mind. As RFM said - the headlight switch. These are a fairly common failure that can result in all kinds of strange lighting issues. Once you have confirmed the headlight switch is either okay (or new) the I would guess the light sensor in the cluster may be bad. To easily confirm that you would need the Durametric Software, a PST2 or PIWIS tester.
  3. You can go the original number (4814) and add or subject by 2. Sometimes that works - sometimes you have to contact a dealer or Becker.
  4. Try 1968 or 1966
  5. What model year please?
  6. Get a PPI and if you are buying from a Porsche dealer get a CPO warranty.
  7. Try 4814 or 4812
  8. RFM is referring to the two solenoids that lock the front and rear latches when you lock the car. I guess if one of these solenoids is bad it might make a buzzing sound.
  9. The alarm/immobilizer/central locking control unit is always under the left hand seat - regardless of whether it is LHD or RHD.
  10. Did you check the front swaybar bushing for wear and tightness?
  11. Uh... the hood release lever is next alarm control unit under the left hand seat. M490 is the amp in the front trunk.
  12. Bridgestone Potenza S-02A N3 is an approved tire by Porsche.
  13. Probably yes, you might want to tape the end of the extra stop light connector though.
  14. Try 0275 or 0273
  15. It might help if you post where you live. Here in California only state approved companies can sell extended warranties. Car dealers (here) can not sell their own warranty they must sell 3rd party approved warranties. Regulations vary from state to state.
  16. That is pretty much true. If the immobilizer/alarm/central locking control box is badly damaged (by water or accident) then none of those systems will work and your car can not be started. In a rare case or two the owner has been able to open the box clean and dry out the circuit board and get it to function again. If not, then you are stuck with buying a box and paying a dealer (or shop with a PST2) to program the immobilizer (to the DME) and the keys to the new immobilizer.
  17. Dealers on Porsche's dealer network get these notifications almost immediately (or over-night). Dealers not on the network and 3rd party shops get notification on a CD that is usually published every month (or two or three in some cases). Our subscription is for the CD version and an update is overdue...
  18. I sent you a PM.
  19. Without seeing the MAF air flow - it would appear that you have an air leak somewhere in the air intake. The engine is seeing to much air.
  20. I hope your MY99 Carrera is a 6 speed (because they didn't make a 5 speed) ;) If you washed the car and did not drive it then you likely have rust/corrosion on the brake disks. It is always best to drive the car after washing to dry the disks so they don't rust. Take the car out to a safe area and apply the brakes medium hard for two or three stops and see if the noise goes away.
  21. Read my latest blog entry (see my signature below). I personally think these are a waste of money.
  22. I am not saying I don't believe you. Do you have a picture of it?
