  1. http://www.renntech.org/forums/index.php?s...ost&p=60336
  2. Yes, it does mount above the mirror mount and the wires run into the upper console with the mirror wires (if you have self-dimming) - so they likely look like one. From the Installation TSB... "The rain sensor functions according to an optical principle. It is fastened to the inner side of the windshield near the interior mirror and mounted in the swept area of the windshield wiper. (Figure 1). The rain intensity is measured with infrared light, and the windshield wiper pause intervals are controlled automatically."
  3. No you do not have to be a Contributing Member. At the bottom of a new post you will see a Browse button. Click that button and find the image you want to upload. Once selected - use the Upload button to actually upload the image to the site here. Then you can use the Manage Current Attachments (drop down list) to add the image to exact location that oyu want it in the message (use the + sign to add it). Likewise you use the X sign to remove an image. If you do not use the plus sign to add the image it will still show up - it will just be at the end of your message.
  4. can that really be the problem? i noticed lately that every time i fill up i get a code soon after, 0446 i believe, and now i started getting these 2 that were discussing here... P0446 EVAP Canister Shutoff Valve (Function) - Below Lower Limit Possible causes: - Purge air line blocked. - Flow resistance of EVAP canister too high.
  5. Yes, those are for widebody cars and have different offsets.
  6. Can you take a pic for us?
  7. How to Post Images
  8. That is the part number for the PASM option - for both cars.
  9. I disagree - if you can do an oil change then you can do both minor and major service too.
  10. The front springs are the same part number. The rear springs are different part numbers. I do not know how the rears are different - but is is likely related to rear weight ratio in the Cayman.
  11. Ok, you have lost me. Your car is a MY03 996 so it's cluster should look like this. Item 4 is the light that lights up when the cruise in ready mode. Where is this other light again?
  12. Those are all the connectors and their wire colors on the left seat.
  13. Did your car have heated seats before? If not the wiring may not be in your harness. or it could be the lumbar support option. Likely need the model and model year from the donor car and the wire colors of the two wires (to look it up).
  14. Try 8799 or 8797
  15. I just ran it again - same number 8825. The radio code will not me on the keys - those are the key numbers. Sorry, looks like you need to call your dealer or Becker.
  16. It only lights when the cruise stalk button is pushed.
  17. They should test the cluster using a PST2. It is possible that it got a voltage spike and is now ruined. If you had over 62.14 miles on the odometer then it can not be reset by a dealer or PST2 (or PIWIS) tester. Only a certified speedometer shop could reset it. Like I said I quest whether the cluster is fully functional - so it needs to be tested. They can clear the airbag fault with a PST2 easily. You need to post the radio serial number in the "Lost Radio Code" thread and I will give you the best guess for your code.
  18. Contributing Members can view TSBs online here. How to become a Contributing Member
  19. As I recall red is the horn and yellow is the airbag.
  20. Try 9134 or 9132 I was finally able to drive for an hour so I can type the code suggested but they don't seem to work, any other suggestions? Thanks Did you read this thread? There are others suggestions you can try before calling a dealer or Becker (I believe Becker still charges $30 and some dealers are free and some charge).
  21. It seems to me that easiest source for the center console would be using the phone prep connector and extend the wires down the console (under the carpet). There is both +12 volts switched and unswitched on the phone prep connector. In the engine compartment? Well, you've got the alternator right there so there is lots of power close - but I would suggest a fuse for whatever you plan on connecting. What are thinking about adding in the engine compartment?
  22. IMHO of course... If I were to pick the "most reliable" Porsche to own right now it would be a GT3. With a normally aspirated engine that is the same as the 996 turbo it is about as close to being bulletproof as can get. Now a GT3 is a little less "comfortable" to drive than a Cayman, or Carrera, or TT but then that would depend on what you are looking for. Of those three a Cayman would certainly have a lot merits - mid-engine and more HP. I am not sure there is a bad choice there - so any would be okay.
  23. :lol: :lol: :lol: At this time I only have a 996. It all comes down to what you want to drive a Boxster (987), Carrera and TT are all Porsche's but very different. I suggest you test drive them all...
