  1. You can either put it behind the front wheel well liner (like it was from the factory) or you can do what I did and put it behind the front bumper with a piece of fishing line tied to the end and the wrapped around the tow point plug. If I ever need to release mine - I just pop the tow plug out and pull the fishing line until I can pull the cable. The choice is yours...
  2. If you are changing the DME connector you will need one of these tools. http://www.etoolcart.com/index.asp?PageAct...amp;ProdID=8893
  3. 9538/1 works either way. You fasten 9538/1 toothed segment to the crankcase using an M12 x 50 hexagon-head bolt (fine thread).
  4. I would email the folks at Brey-Krause (http://www.bkauto.com/). They have likely made brackets for most seats.
  5. Have a look at the Porsche Standard Tools list. Available to Contributing Members to download here. And/or Porsche Workshop Equipment here.
  6. Try 8932 or 8930
  7. You usually find it on the Maintenance Manual sticker, the sticker under the front hood and on the chassis near the left front light (inside the carpet of the front trunk). See diagram below...
  8. :welcome: :lol: :lol: :lol: Sorry, to laugh but your dealer must not read their TSBs (Porsche Technical Service Bulletins). They need to read TSB 1/00 701 Noises In The Dashboard Area -- dated 6-30-00. This TSB has series of fixes for dash noises and is 9 pages long. Contributing Members here can view all the TSBs online.
  9. 996.653.101.06 or 996.653.101.08 or 996.653.101.09 Will all work and match properly.
  10. The rear cable is behind the left rear taillight.
  11. Sorry, I do not understand 08/2003. What model year and front or back or both?
  12. http://www.renntech.org/forums/index.php?s...ost&p=62328
  13. Loren
    New to Forum
    :welcome: Both look great!
  14. :welcome: I had a 1974 2.0 liter RoW spec car - loved it - wish I still had it.
  15. Did you remove the excess oil? If so give it a few days to clear.
  16. It might work but the buttons and deign are for a MY03 and newer cars with the matt black finish. Your car is the last year of the glossy finish buttons and trim.
  17. The simple test is the buy/borrow a micrometer and see if the rotor thickness is within spec. You can also check the runout. If they are within 1 mm of the minimum spec I usually change them out. Remember SUVs are a very heavy vehicle and it will go through front rotors. My wife's SUV (Jeep) was the same way, the factory rotors barely lasted 25,000 miles. I put a set of Brembos on and now have 75,000 miles on them and are still with spec.
  18. http://www.renntech.org/forums/index.php?showtopic=6203
  19. That maybe close but he has a 987 -- not a 986. It is similar but not quite the same.
  20. Would a CDC-3 work in place of a CDC-4 or is it incompatible? I have a CDC-3 that is in good working order. Nope, CDC-4 is MOST (fiber optic) interface - CDC-3 is wired. So, CDC-4 only works with MOST radios.
  21. Did you look here?
  22. 6 speed or Tiptronic? 6 speed oil smells like transmission oil (strong). Tiptronic fluid is red and lighter weight than motor oil or manual gearbox oil. Look at the DIY diagrams for oil change and manual transmission oil change (assuming your car is a 6 speed) and see which looks like the drain you removed. This is the oil drain plug - an 8 mm hex (as I recall). The clean area.
  23. :welcome: Model and year of your car please...
  24. Yes, it is similar. It still sits high on the transmission near the bell housing. Remember PentoSin for the clutch circuit on TT/GT2. Ah thanks. I'm sorry but Pento-who? The 996TT DIY section is empty... I can't find any info. It's for a friend's car and I'll be helping him with the fluids. Look in your Owners Manual the clutch and power steering use only Pentosin CHF 202 (Pentosin CHF 202 supersedes CHF 11S and they can be mixed).
