  1. Please explain - Porsche PCM NAV? or after market?
  2. Try 6904 or 6902 Loren: Neither of these two worked. Any others to put in? THANK YOU. Please read the previous posts - if the numbers I gave you do not work then you need to contact your dealer or Becker. Last I heard - Becker charges $30.
  3. :welcome: Please try a search next time before posting your issue - this is a current discussion http://www.renntech.org/forums/index.php?s...showtopic=11895
  4. Ask one of the guys that did it here.
  5. Well, for the 996 the trick was to use the GT3 rollbar kit to cover the holes etc.
  6. Could be - fix the known faults first.
  7. Check the wiring at the sensors and then follow then back to the engine area.
  8. :welcome: P0341 Camshaft Position Sensor 1 - Signal Implausible, Short to Ground, Short to B+ P1397 Camshaft Position Sensor 2 - Signal Implausible, Short to Ground, Short to B+ Potential causes: - No power supply. - Short circuit to B+ - Short circuit to ground. - CMP sensor faulty Check the wiring...
  9. Try 6904 or 6902
  10. If this item is For Sale - please post it in the appropriate area and include an asking price.
  11. As long as you get the kit that includes the 5 mm spacers AND 5 mm longer wheel bolts you should be fine.
  12. If you do a price list search for 996.642.030.02 it tells you to use 000.044.900.92 NAV SYS RETROFIT KIT -- US MSRP $638.22
  13. Try 1363 or 1361
  14. Not with the right tools and small hands.
  15. Did you check our Special Offers section? "smartTOP www.wilhelmy-it.com is giving RennTech.org members get an instant rebate of $10 on each smartTOP module OR a RennTech.org Group Buy rebate of $20 per module if 10 RennTech.org members do a coordinated purchase at the same time."
  16. If the pedal is much harder than it was - that is a sure sign the clutch disc is gone. Best to get it fixed before any damage is done to the flywheel.
  17. Try 3328 or 3326
  18. Probably - I seem to remember a value of 100 ohm resister.
  19. From your VIN... Front pads (18" rotors): 955.351.939.14
  20. Please check your options list and see if it says" I1LK = 17" rotors or I1LL (or I1LK) = 18" rotors
  21. Enlarge the pic - it is taped down right above the electrical connector.
  22. Ok, got it. Sorry, I need to know if your front rotors are 17" or 18". Rear pads: 955.352.939.20
  23. Did you try Sunset Imports (Porsche Parts at Dealer Cost)?
