  1. http://www.renntech.org/forums/index.php?showtopic=15193
  2. Try 9110 or 9108
  3. Could be a loose or bad upper strut mounting/bearing.
  4. Provided you have a laptop to run these on... - the Durametric software at $247 is Porsche specific and can do many other things like reset airbag lights. - as a really good all-around OBD II tool Car Code OBD II for about $122
  5. Hmm... Wrong spark plugs? What spark plugs did you use? How did the coil packs look? Are you sure the coil pack connectors are all the way on? It would appear that your problem is on cylinder 4, 5 and 6. So if all those other items are ok - then your Variocam control may not be working on that side.
  6. :welcome: Have you checked the main fuse? (D8 on your fuse panel) If that is okay then check the fuse on the back of the radio. You will need the radio removal keys for that.
  7. Model and year of your car? In most cases you can use the directions in the TSB 11/98 6827 Automatic Dimming Rearview Mirror (Int.) -- dated Jun 24, 1999. As a Contributing Member you can view this TSB online here.
  8. :welcome: What was the fault code(s)? There are numerous fault codes that deal with O2 sensors.
  9. C00 - (emissions for) country Germany (you can find this in our Option Code Lookup section) I don't find 232 in any of my options lists. The contents of the special option packages like M013 would vary some from country to country. In the US we call that "bundling". The only listing I have seen in in that countries order guide. From our Glossary: ABD = Automatic Brake Differential - A traction control program which works in conjunction with the new ABS/5 brake system. The ABD is active up to 45 mph. The system applies brake pressure to the rear wheel with the least amount of traction.
  10. Yes, remove the left front tire and the the wheel well liner and everything will be there to access.
  11. P0430 TWC Conversion, Bank 2 – Above Limit This usually means a bad cat - as long as no other codes are also recorded. Are you sure there are no other codes?
  12. Try 4881 or 4879
  13. Of course you mean Sunset Imports (Porsche Parts at Dealer Cost)? I would stick with Porsche's revised coil packs - you want 948.602.104.03 or 948.602.104.05.
  14. Last time I did this was at a work on cars day - so the engine was still warm. I don't recall it being a big deal - I just wiggled it back and forth until it came off. Maybe a warm (but not hot) engine would help?
  15. Did you check for a bent lever on the transmission?
  16. :welcome: Most likely because more MY03 reported problems than other model years. Chart below is from Consumer Reports
  17. Try 6608 or 6606 Thanks for the quick reply loren and the help...but after entering the code, my deck is stuck on the "wait" screen. i tried unplugging the harness from the back of the deck and also the neg cable on the battery for about a min and a half to try and reset, but no luck. any advice? thanks again! Well, you didn't read this thread did you... WAIT has been explained here several times. You need to drive the car to clear the WAIT message.
  18. Try 6608 or 6606
  19. The black pads are the quiet ones - so maybe you need have your dealer have a look at them.
  20. :thumbup: Yes, after the changes you have to turn the car off - then back on to re-initialize the controllers. But you need to do that for most all programming changes.
  21. :welcome: My airbox has no wire mesh or plastic screen - I removed them. IMHO if you keep your air cleaner maintained you will not have any problems.
  22. If you want the ability to reset your service indicator and reset an airbag light - only the Durametric will do that.
  23. :welcome: Please do a search here - this has been covered in a great deal of detail.
