  1. Good info, Loren. Are these also the ranges for a 987S? Thanks. Yes, the 9x7 series use the same DME (so far).
  2. The 6 ranges are: Range 1: 7300-7500 RPM Range 2: 7500-7700 RPM Range 3: 7700-7900 RPM Range 4: 7900-8400 RPM Range 5: 8400-9500 RPM Range 6: 9500-11000 RPM You really don't need to worry about anything other than ranges 4 to 6.
  3. Sorry, for your trouble. XenonMods was removed from our Special Offers section here after delivery and responses became very "spotty". Here is a thread of previous experiences... http://www.renntech.org/forums/index.php?showtopic=6386
  4. Just an FYI... Those manuals are missing pretty much the last 50 plus updates (which is several thousand pages).
  5. I see two MY08 Cayenne's on my latest salvage list so it might not be as long as you think...
  6. Thanks Loren - but is there any benefit to unplugging the battery so the DME gets the new MAF parameters when going from the 125 00 to the 125 01 MAF, or won't it make a difference? And any thoughts on whether the idle issue I mentioned was related to the MAF or just a coincidence? Yes, anytime MAF work is performed you are changing it's base reading. So, disconnecting the battery for 5 minutes then reconnect it and let the engine re-learn it it's idle and power program.
  7. Yes, my mistake (Porsche has made this very confusing). If you go from the 124 00 to either 125 00 or 125 01 then you need to re-program.
  8. The RoW come 10 mm lower - you can also get the "sport" suspension which will lower the car 20 mm. Your third option would be coilovers (i.e. PSS9s). Only with the coilover could you corner balance. What exactly are they quoting you for $1100?
  9. Hmm... that is all that I see on my March 2008 parts list. Either I am looking in the wrong place (I've looked at dash and ignition) - I don't see anything else.
  10. Other than the clips inside the headlight openings it is pretty much the same as the 996. Have a look at my 3rd radiator install for pics on a 996 http://www.renntech.org/forums/index.php?showtopic=7070
  11. You are correct if you upgrade to the newer part number (...125 01) then you must use a PST2 or PIWIS to update the DME map.
  12. I would be concerned about the "jelly" coolant - that is what happens when you mix two incompatible coolant types.
  13. http://www.renntech.org/forums/index.php?s...c=16079&hl=
  14. There were some drive shaft changes on the 993 depending on the model year. Based on that you may have to replace the whole drive shaft.
  15. The last spec on "Approved Transmission Oils" is The parts are: Filter 955.307.403.00 gasket for filter 955.325.443.00 gasket for pan 966.397.016.00
  16. Sorry, we do not publish manuals or sections of manuals here.
  17. How about I send you the factory procedure and you write it up with pictures here?
  18. Sometimes the cylinder head can be welded (a special process for alloys). If not, then both the cylinder head and cam cover are replaced (as they are a matched set).
  19. Is it the nut that holds the ignition switch in place? Does it unscrew? If, so, then it is 997.618.759.00 -- retail $1.98
  20. :welcome: I only see two in Porsche's parts/price list and one is marked for Tiptronic and one is marked for 6speed.
  21. The car is Lapis Blue with a dark blue top. The discs are dark blue. Thanks Lorem! I meant the trim color - so they match - do you know the color name? Your choices are: Black - 996.555.457.00.A10 Graphite Grey - 996.555.457.00.C50 Metropole Blue - 996.555.457.00.G10 Space Grey - 996.555.457.00.B50
  22. I don't think you can mount it without removing the front bumper re-enforcement - it bolts to the same point on the left side.
  23. Just remove the wheel well liner. Several plastic rivets and a couple of plastic nuts as I recall.
