  1. Loren
    GT3 wing shim
    Carnewal.com http://www.carnewal-europe.com/cpx_p96125.htm
  2. It is likely not the struts themselves but the upper strut bearing (where it mounts to the car). Struts are your shocks.
  3. If you were local I would do it for you. Check the PST2 & Durametric Tool Registry list for someone in your area with a PST2 or PIWIS. Folks here won't charge you - dealers likely will. http://www.renntech.org/forums/index.php?showtopic=13779
  4. Is your OBC turned on now? That is, do you see outside temperature displayed? If not you will need to find someone with a a PST2 or PIWIS tester to turn it on for you (a 5 minute job).
  5. :welcome: Here is the technical description from the MY99 Porsche Service Information Book. The whole book as well as many others are available to Contributing Members here online. OBC_MY99.pdf And here are the scanner pages (on OBC) from my MY99 Carrera. I have not scanner the whole manual since doing so breaks the binding. Porsche did not start offering PDF versions of the manuals until MY2003. MY99_OBC_Owners_Manual.pdf Where are you located?
  6. I would clean the MAF and reset the codes then see if it comes back.
  7. Sorry, Chuck he says his car is a MY01 - so it would be the electric release.
  8. Try 7626 or 7624
  9. Try 0135 or 0133
  10. 999.571.076.02 Headlight tool -- MSRP $11.99
  11. Do not let it get the control box under the drivers seat (that is your central locking/alarm control). Very expensive. Do a search here on drains - I have posted diagrams for both coupe and cab.
  12. I think it is law in the US - so that you don't mistake fogs for brake lights.
  13. On US cars there is no bulb on the right side and only the one fog light is wired.
  14. Look for a bad ground. An ohm meter should help you find the problem.
  15. Have a look at the Adjusting Hood Latch Mechanism DIY... http://www.renntech.org/forums/index.php?showtopic=5619
  16. The 997 has a different part number 997.645.140.02. Sorry, I do not know the differences. The 996 change does not have a superseded part number.
  17. Homelink did not come out (for Porsche) until the 9x7 series cars (and the Cayenne). As I recall there are two pieces - one that goes behind the front bumper and one that is in the mirror. I doubt the 997 mirror will work in a 996 since it attaches to roof rather than the front windshield.
  18. Either can be used. You need a PST2 or PIWIS tester and then follow the procedure in TSB 5/02 9120 Activating the CD Radio "Porsche CDR 23" -- dated 10-11-02.
  19. Try 8240 or 8238
  20. That has all been covered in this thread previously (several times).
  21. There is a TSB on this...
  22. Look for a Brown/Blue wire from the original radio connector and remove the pin and tape it (or cut and tape the wire).
  23. The radio/nav wire is in the connector plug (unless you cut it off).
  24. Durametric usually fixes errors pretty quick when folks tell them about the error. NAV/Radio wire (when using after market) -- Taped up and tucked away.
  25. Try 0327 or 0325
