  1. http://www.renntech.org/forums/index.php?s...ost&p=93149
  2. That part number is correct.
  3. Try cleaning and lightly lubricating your clutch return spring (on the pedal assembly).
  4. Try 0398 or 0396
  5. It would not hurt since you are changing the airflow somewhat.
  6. Please read through some of this thread - that has been explained several times...
  7. Try 3261 or 3259
  8. Sorry, all of your part numbers are missing the last two digits. Since it says VariCam and not VarioCam Plus that would imply that it is a 3.4 liter engine (MY99-MY01).
  9. Try 0571 or 0569
  10. :welcome: From the Documents Menu at the top of the page - choose "Option Codes Lookup". http://www.renntech.org/forums/index.php?autocom=options
  11. I would call around to various dealers and get part cost plus shipping costs. I would start with Sunset Imports (Porsche Parts at Dealer Cost).
  12. :soapbox: Read my Blog (link in signature below) for my 2 cents....
  13. That sounds correct. The seat heater control unit is 996.618.521.00. They are the same on both sides so you should be able to swap them and verify that it is the problem.
  14. Are you sure they are the right sensors and all the wires are connected?
  15. P1115 Oxygen Sensor Heating 1 Ahead of Catalytic Converter - Below Lower Limit P1119 Oxygen Sensor Heating 2 Ahead of Catalytic Converter - Below Lower Limit P1117 Oxygen sensor heating 1 behind catalytic converter – below lower threshold P1121 Oxygen sensor heating 2 behind catalytic converter – below lower threshold Very odd that you would get all four O2 sensors with no heating. Something get disconnected?
  16. The first faults say the DME is not getting a signal from either cam position sensor. Now you are getting a fault that says it can't change the camshaft adjustment via actuator - this would seem logical to me. If you don't feel comfortable tracking this down you should get the car to a shop that specializes in late model Porsche's and has a PST or PIWIS tester.
  17. Have a look at TSB 24/05 9112 Navigation Module For PCM Installation Instructions (I No. 670) -- Feb 14, 2006 for the 997. It should be the pretty much the same .
  18. Please explain - Porsche PCM NAV? or after market?
  19. Try 6904 or 6902 Loren: Neither of these two worked. Any others to put in? THANK YOU. Please read the previous posts - if the numbers I gave you do not work then you need to contact your dealer or Becker. Last I heard - Becker charges $30.
  20. :welcome: Please try a search next time before posting your issue - this is a current discussion http://www.renntech.org/forums/index.php?s...showtopic=11895
  21. Ask one of the guys that did it here.
  22. Well, for the 996 the trick was to use the GT3 rollbar kit to cover the holes etc.
  23. Could be - fix the known faults first.
