  1. I think you will need to change the bumper to fit the other front spoiler lip. Probably best to confirm exactly which front bumper you have - because dealers are not supposed to add the rear spoiler without the adding the front bumper/spoiler. The correct part number for the Aerokit Cup II front bumper is 996.505.986.02.G2X.
  2. In Fremont - talk to Alex at Sharkwerks - tell him I sent you. Oh... I think he only does GIAC - but ask him. (510) 651-0400
  3. Perhaps you can find someone local with a PST2 or PIWIS that will turn it on for you. It only takes 5 minutes.
  4. Check for a bad connection in the steering wheel.
  5. No the Durametric does not do that (yet). I am on North side of Roseville - I can reprogram your door locks -- for free. PM if you want to get together.
  6. :welcome: We suspect that 226 is 18" tires. My car has that option too and it is the only thing missing from any Porsche lists. As of MY02 the fuel filter is in the fuel tank and never needs replacing (under normal use).
  7. This would indicate an O2 sensor is not reading/operating correctly - or you have an exhaust leak.
  8. Please ask for and get the magazine's permission before posting one of their articles here. Total 911 has granted that before - but as a courtesy (to them) I am removing the link until we have permission to distribute this article.
  9. Try 0261 or 0259 Niether worked! any thoughts? Please... it is all covered here before (if folks would just take the time to read). You can try two digits up or down of the first number I gave you - that has worked for some. If nothing works then you either need to contact your dealer or Becker. Last time I checked Becker charges $30 to look up up your code.
  10. Have a look a Tool Pants picture - sometimes it is tucked up behind the the airbag controller (box with orange label).
  11. http://www.renntech.org/forums/index.php?s...ost&p=43454
  12. The hood is open light? Sounds like a bad harness. The only thing the -051 harness should change is the spoiler light (not the rear lid light).
  13. I think it is one double relay? (one relay that takes up two spots) 996.615.111.00
  14. Try 6411 or 6409 Loren!~ TY for getting back to me so quickly... unfortunately neither the 6409 or 6411 worked?? Do I try 6407 or 6413? or? Todd Yes you can try that - it has worked for a few folks. Just keep trying a two digit difference each time. If all else fails you will need to contact a dealer or Becker.
  15. So does the engine really stumble when you back off the gas? or could it be something like a loose rear swaybar? An RMS (or IMS) problem may be a few drops from the center of mounting point between the engine and transmission or a gusher. There are a lot of cars out there that have no RMS/IMS problems but there are a good number that do. So I would not worry unless you starting seeing an oil puddle under the car - and confirm the location where it is coming from. There are other places oil leaks can occur.
  16. Seems likely that the two other possibilities are the relay (double relay) or the headlight switch.
  17. To remove rearview mirror glass - Carefully pull the rearview mirror glass (2) out of the metal clips. Disconnect electrical plug connection (3).
  18. If you want the keys/immobilizer to work then then you will need to transfer the program data from the old one to the new one. I do not think it will work any other way.
  19. My name is Loren. Try 3274 or 3272 Loren, I tried the codes and they didn't seem to work. I'll retry in the morning after the "WAIT" disappears again. I might have mistyped. Sorry about the name mispell. I noticed right after I posted it. I have a friend named "Lauren" as well, so my fingers are just used to typing it. Thank you again for your help. Mike Loren, The two codes didn't work. Any other suggestions? Thanks again for your help. Please... it is all covered here before (if folks would just take the time to read). You can try two digits up or down of the first number I gave you - that has worked for some. If nothing works then you either need to contact your dealer or Becker. Last time I checked Becker charges $30 to look up up your code.
  20. Try 5511 or 5509 Neither worked. Besides contacting Porsche or Becker, are there any other suggestions? All covered here before (if folks would just take the time to read). You can try two digits up or down of the first number I gave you - that has worked for some. If nothing works then you either need to contact your dealer or Becker. Last time I checked Becker charges $30 to look up up your code.
