  1. Try 6608 or 6606 Thanks for the quick reply loren and the help...but after entering the code, my deck is stuck on the "wait" screen. i tried unplugging the harness from the back of the deck and also the neg cable on the battery for about a min and a half to try and reset, but no luck. any advice? thanks again! Well, you didn't read this thread did you... WAIT has been explained here several times. You need to drive the car to clear the WAIT message.
  2. The black pads are the quiet ones - so maybe you need have your dealer have a look at them.
  3. :thumbup: Yes, after the changes you have to turn the car off - then back on to re-initialize the controllers. But you need to do that for most all programming changes.
  4. :welcome: My airbox has no wire mesh or plastic screen - I removed them. IMHO if you keep your air cleaner maintained you will not have any problems.
  5. If you want the ability to reset your service indicator and reset an airbag light - only the Durametric will do that.
  6. :welcome: Please do a search here - this has been covered in a great deal of detail.
  7. Do you have standard pads or performance pads? What color is the pad side area (black w/stripes or light green)?
  8. Loren, Is it the same part number for MY00 C4? Fuel pump 996.620.103.00? thanks Yes, MY99-01 C2 and C4.
  9. Some of that will depend on what country you live in... Please add your location to your profile.
  10. Sorry, but I think you are out of luck. Porsche does not sell them separately. You might try someone with a bad knob and good shift pattern or a salvage yard.
  11. I did not paint mine - it came that way. Mine is a factory installed aerokit cup (option IXAA).
  12. 1. He needs to make sure the model type is proper coded in th DME - you can not change anything unless it is. And, there were a bunch of Boxsters that came from the factory without the model type coded. 2. As of MY03 (with the new instrument cluster) the OBC has to be turned on in two places - the DME and the cluster. 3. On the newer cars I do not think you will see any display change until you add the switch.
  13. :welcome: Please do a search here - P1128 and P1130 have been covered many many times (and it is not likey your fuel filter).
  14. That sounds like a logical plan. You can get rid of the radio code by removing the wire from the radio harness and taping it. Look for a Brown/Blue wire from the original radio connector and remove the pin and tape it (or cut and tape the wire).
  15. Fault code 33 - Passenger compartment: monitoring sensor faulty Possible cause of fault Replace passenger compartment monitoring sensor Fault code 42 - Wrong key or wrong transponder pill Possible cause of fault - Wrong transponder - not adapted to the vehicle (fresh battery and re-training maybe needed) - Short circuit to ground/voltage or open circuit in the wiring between the signal converter and alarm system control module Fault code 54 - Radio receiver defective Possible cause of fault - Alarm system control module faulty (also if you have an after market radio this fault would occur too). Fault code 60 - Central locking limit position 'Locked' not reached Possible cause of fault - Central locking switch faulty - Short circuit to ground/open circuit in wiring between the alarm system control module, central locking switch or door locks - Driver's/passenger's door lock faulty - Control module faulty (sometimes this fault also occurs if you hit the alarm set button before the door is closed completely).
  16. Then please state that when you post... or put your location in your profile. http://www.renntech.org/forums/index.php?a...int_box_row_add 48,000 miles. It does not hurt to do it sooner - especially if you do not know the car's history.
  17. http://www.renntech.org/forums/index.php?a...aint_box_us_add 60,000 miles.
  18. thanks got it off Same on the 2008 Boxster S? Yes, it is the same piece.
  19. Sometimes it is a small pebble caught between the rotor and the splash shield or other debris. If it does not happen again I would not worry about it.
