  1. I don't think it matters whether it is in gear or not. I think it is just stuck on the shaft. I would likely try to pry it a little with two wooden pry sticks - maybe just enough to loosen the stuck shaft.
  2. :welcome: Sorry about your trouble. Do a search here and you will learn how to access the emergency release cable behind the right front wheel well liner.
  3. mcm97, TSBs are viewable on this site by our Contributing Members. If you would like to find out more about becoming one click here.
  4. It should come straight out if the transmission is horizontal.
  5. 1. Check the power supply for the signal converter:Disconnect the connector on the signal converter. Voltmeter at plug housing pin 4 (negative) and pin 5 (positive).Ignition key inserted. Display: Battery voltage.2. Check the control line for the signal converter (pin 6) to the alarm control unit plug I pin 4 for continuity, positive short and ground short.3. Check the status line for the signal converter (pin 7) to the alarm control unit plug I pin 12 for continuity, positive short and ground short.4. Check the data line for the signal converter (pin 8) to the alarm control unit plug I pin 3 for continuity, positive short and ground short.
  6. The good folks at Sunset Imports (Porsche Parts at Dealer Cost) have made a special offer for RennTech.org Members. You can now purchase the full factory Boxster (986) Service Manual Set (15 volumes) for only $200. Considering what I paid for my manuals (years ago) this is a fantastic price. To place your order email porscheatcost@sunsetimports.com or call them at 1-800-346-0182. Thank you Sunset Imports!
  7. You would need to replace all the linings - which can be done. But... the large main lining (item 6) in leather has a US MSRP of $1070.96 :eek:
  8. Drive the car - if the lights came on after a battery change (smog check) then there will be no faults and they will reset in a few miles. If there is still a problem will not go out and you will need a code reader to see what the issue is.
  9. There are many things it could be before your DME (Engine Computer). You should find a shop with some test equipment like the Durametric Software, a PST2, or PIWIS tester and have them look at your air flow (MAF reading). And, as I said check for damage on that one sensor - it is fairly common to have mice (or other rodents) eat away the insulation on wires during storage. We've seen and heard it it here many times.
  10. Try 8806 or 8804
  11. :welcome: P1571 (Porsche code 39) Immobilizer – Open Circuit / No Signal – Open circuit in wiring between DME control module and alarm system – Short circuit to ground or short circuit to B+ – Alarm system control module faulty Check to see if it is wet under the left hand seat. When water gets into the car the first place it runs to is the alarm/central locking/immobilizer box under that seat.
  12. P1124 Oxygen Sensing Adaptation Area 1 (Cylinders 1 - 3) - Rich Threshold P1126 Oxygen Sensing Adaptation Area 1 (Cylinders 4 - 6) - Rich Threshold This means that your mixture is running too lean - that is, the DME can not make the mixture rich enough to compensate for additional air. Potential fault areas: - Intake air system leaking. - Fuel pressure too low. - Volume supply of fuel pump too low. - Fuel injectors fouled. A really bad MAF reading can cause this as well as intake leaks (cracked oil filler tube, AOS, etc., etc.) P0130 Oxygen Sensor Ahead of Catalytic Converter (Cylinders 1 - 3) - Intercore Short Circuit or Limited Voltage Increase - Oxygen sensor - Wiring harness - DME control module This sensor needs to be checked to see if it is cracked (ceramic) or if the wires are damaged.
  13. Mine is now 9 years old - cleaned counted times and looks like new. $117 sounds like a good deal too - I paid $120 nine years ago.
  14. Here you go (since you might also need the small parts)... 2004_tt_wheel_liners.pdf
  15. Did you read the FAQ I sent you to? I think not...
  16. Try 4787 or 4785
  17. 1. Please do not post titles in ALL CAPS - that is shouting on the internet and is is considered rude. 2. Go to the link that I have given you (several times) -- Lost Radio Code - post your request here. Click on the Add Reply button and type your request - click the Add Reply button at the bottom to submit your reply post.
  18. Try 0956 or 0954
  19. The "Approved Tires" list for each model is available in Porsche TSBs. All TSBs are are available here for viewing by our Contributing Members.
  20. PLEASE post this in the Lost Radio Code thread (this is the third time I have asked you). Please DO NOT PM me or email your radio code request - I will only answer them in that one thread.
  21. Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  22. The 4th stalk sits below the turn signal stalk (similar to the cruise control on the right side of the steering wheel). The 4th stalk controls the display for the OBC (On Board Computer) which gives you outside air temp, mileage info, speed gong, etc.. See your Owners Manual for details of what OBC function are in your model year car. This OBC hack (mod) process is a common add on for many owners. Step one is to have someone turn the OBC function on in your car (using a PST2 or PIWIS tester).
  23. Porsche has a couple of paint manuals but I do not have access to them. Check with your local dealer and see if they have these and if you could look at them. That would likely be a good place to start.
  24. Try 0938 or 0936
