  1. I show the 433 MHz control box as 997.618.225.03 It has a US MSRP of $450.15 It mounts behind the front bumper - so that would need to come off to get access.
  2. According to the parts list that should fit any Cayenne MY03-06.
  3. http://www.renntech.org/forums/index.php?a...code=_9x6_Werks Buy DVD #1
  4. No swapping DME won't work because you would need to reprogram the immobilizer each time. You should however check to see that the connections to the DME are tight. I had one once that was 3/4 of the way unplugged.
  5. http://www.homelink.com/training/print.taf?i=first
  6. I think that reference to SME is a typo - I think they mean DME.
  7. I sent you some info... Looks like it could be a low voltage condition. Have you disconnected the battery or had electrical problems recently? If not, I would erase the code and see if it comes back.
  8. :welcome: Not much info in a 10 digit VIN...
  9. :welcome: Unless you are positive the relays are working start by swapping them with another car that is working.
  10. Thanks! I guess I hadn't seen one of the newer kits.
  11. Try 4615 or 4613
  12. ... or a small rock caught between the disc and the splash shield.
  13. :welcome: Unless they are different than I remember the whole bulb holder just pull straight out - then you can replace the bulb,
  14. The wiring for the switch just goes to the relay and the cluster. I can send you the wiring diagram if you are comfortable with that.
  15. Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  16. Try 2664 or 2662
  17. If the wiring for the switch was there then that is the first time I have heard that. In the past the switch (and switch wiring) was not included. The wiring that was included was for the connection to the cluster.
  18. Just buy some wire (like the spoiler mod).
  19. hi all i need to get a navigation code have the pcm code but i believe i need the nav code only not sure how to access it since it doesnt illuminate on the screen it asks for the pcm code which i put in but rejects it and after a few tries it make sme wait a hour!! thanks Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  20. No, the switch wiring is not included - never has been.
  21. If your check engine light comes on then there should be a code. Very few codes clear themselves on the sane drive (usually takes several drive cycles). What did you use to read the codes? Also, where are you located?
  22. http://www.renntech.org/forums/index.php?showtopic=19509
  23. Not sure about a CR-210 but on the CDR-220 you just enter the code and wait. It then responds with the radio station.
  24. Try 0206 or 0204
