  1. it should look like the one in the DIY: How to change your Pollen Filter (Cabin Filter, Particle Filter)
  2. OBC is a separate computer so the functions in the cluster should not change. Any OBC displays in the NAV will not be there with an after market NAV.
  3. Pollen filter = Cabin filter They are the same. Porsche uses the words interchangeably.
  4. Lost Radio Code - FAQ, PLEASE READ THIS FIRST The radio show: Pr-vers. R1097 Serial N w5018969 Try 7481 or 7479
  5. It's been discussed here many times... http://www.renntech.org/forums/index.php?showtopic=17011 http://www.renntech.org/forums/index.php?showtopic=3169
  6. DTC 70 or P0740 = Solenoid valve, torque converter clutch. Open circuit/short to ground. 1. Check ATF level. Erase the code and take for a test drive. 2. Re-check for fault codes. 3. If the fault recurs after the test drive and no other faults are stored, the following fault possibilities can be present: -Electrical activation of pressure regulator 4 not OK (diagnostic trouble codes 83 and 55 present?). -Mechanical defect in pressure regulator 4. -ATF supply to the torque converter clutch not OK. -Converter defective.
  7. Check your wheel offsets.
  8. I still think you need to see your dealer (since the car is under warranty). You do not lose almost 2 gallons of coolant without some major going on.
  9. My mistake - I was looking at the wrong light. For standard arched fenders: 955.631.035.00 Left Clear Side Marker 955.631.036.00 Right Clear Side Marker US MSRP $21.43 (each) For the optional wider arched fenders (I6GF): 955.631.035.20 Left Clear Side Marker 955.631.036.20 Right Clear Side Marker US MSRP $30.99 (each)
  10. Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  11. Check ignition coil(s). Resistance between terminal 1 and terminal 15 at 20°C (68° F): 0.3 - 0.7 Ohms
  12. I don't think the sunroof is that smart. I think all the "brains" are in the drive motor/circuit board assembly. For your older car I wonder if the sunroof drive was upgraded per TSB 12a/98 6014 New Sunroof Drive Motor -- dated 9-10-99. It says "As of February 1, 1999, and VIN: 99 XXS 62 5423, a new tilting/sliding roof drive assembly with enhanced circuitry is installed in production. The new drive assembly has optimized final-position settings that result in lower noise levels."
  13. Try 7224 or 7222
  14. Lost Radio Code - FAQ, PLEASE READ THIS FIRSTe
  15. I am going to close this as you already have a thread on this subject.
  16. You need have your car towed to your dealer. Could be a blown headgasket or other internal damage.
  17. They should be fine out of the box (as long as you do not drop them ;) ).
  18. My sunroof switch loses it's memory a couple times per year. I re-train it and it is fine for several months. I think this is just a problem with these cars.
  19. Look for leaks first - almost two gallons of coolant is a lot to lose. I assume no smoke?
  20. Since your car is still under warranty - I suggest you take it to the dealer and get the complaint documented. They can read any pending codes and have a look at your car's current OBD II performance. Certainly if you have had any "miss" there should be fault codes.
  21. For Gen 2 Cayennes the parts list shows the same parts for US and RoW cars.
  22. I sent you a PM with some info.
  23. Both cats and muffler can break internal welds and make ticking, rattling, clunking sounds. Not to mention heatshields. You might want to check those out first.
  24. Try 8768 or 8766
  25. Bad coils have cracks - and usually end up causing a misfire and CEL. I guess you could try cleaning the MAF.
