  1. There is no service requirement for the fuel filter (since the returnless fuel system was introduced in MY02). It is integrated in the fuel pump (item 4 above) and unless there is contamination there is no need to replace it.
  2. Try 9036 or 9034
  3. Front bumper is easy enough. The side skirts for a Mk1 areokit are held in place with epoxy - that takes 24 hours to cure. So I think you should do that at home where the car can sit for at least 24 hours.
  4. No wonder - the CEL is on... :lol:
  5. Joint sealer - it shows differently on different paint colors.
  6. Well, the injector could still be working somewhat. It could be just not letting the right amount of fuel in - or sticking open and always letting fuel in. I guess unless you have a way to measure the fuel injector cycle (oscilloscope) then you don't know for sure if it cycling properly. So, if the injector is getting the 12 volts (as stated above) then chances are the injector is bad.
  7. Loren, my battery is totally dead. I have searched for and read every post on this emergency cable and still haven't been able to find it to release my front hood. I have a USA 2002 Boxster S, have felt everywhere that seems logical in the top of the left and right wheel wells, behind the coil, pulling away the plastic liner. You mention the "left" wheel well, is that also the driver side wheel well on this car? Also, I found instructions both here and on another site that described an unlocking sequence that should have popped my hood, using a battery charger to that red pull out fuse, with the left door open, turn the charger on, the alarm goes off, then push the door latch to the closed position, lock and unlock the door and then open the hood. Multiple attempts at that failed also. Do you have any ideas here? I'm now getting a little desperate. Thanks, Mike Um... I can understand that you've seen this question a lot, AND there's other info out there that clouds the issue, especially when half the posts here talk about using a battery charger to open the trunk and that rarely works for anyone, and nearly everyone has trouble finding the emergency release cable the first time. I've some time scouring the web for more info, and found this. You'll note that the "driver side" wheel well is ambiguous,thus my question about which wheel well. Also the descriptions of location often mention the cable is "AFT of the coil tower" but on your site folks have mentioned it being in front of the tower: Front and Rear Hood Release Inoperative [grp5 1/96 5510 1/21/97] 1pg Should the front and rear hood releases become inoperative due to a disconnected or discharged battery, the following procedure will allow the hoods to be operated electrically under these conditions. • Open the left door. • Using an external battery, connect the negative lead to the door stop. • Connect the positive lead to both sides of fuse "C3" (see illustration below). • With the door open, move the door latch with a screwdriver into the closed position. • Using the key, lock and unlock the door. • The front and rear hood releases can now be operated. Note: If the vehicle is in the workshop and the battery must be disconnected, try to park the vehicle in a safe area where it is not necessary to latch the front hood. The diagram shows the same stuff as the bulleted directions above except it shows putting a 30 amp fuse between the external battery positive terminal and the C3 fuse. [Note: none of this worked, however one poster here mentioned removing the key from the door and inserting it into the ignition and turning it and that silenced the alarm and allowed for the hood release to operate. I will try that sequence tomorrow before attempting the cable release mystery tour again.] 7.9 Accessing the Battery when it is Dead The Boxster has a minor difficulty. If you have the alarm and the battery goes dead, you cannot open the front trunk to get to the battery to jump start it. There have been three techniques discussed for entering the front trunk when this problem manifests itself. 1. There is a Porsche Technical Bulletin describing one way that works for entering the car. See Front and Rear Hood Release Inoperative [grp5 1-96 5510 1-21-97]. A description of what one owner did to construct the device mentioned in the bulletin is shown at http://grr.xoc.net/boxster/articles/dooropener.asp . 2. It may work that a cigarette lighter to cigarette lighter jumper cable will power the car enough to open the car. This has not been confirmed to work, though. Make sure that you carry the jumper cables in the passenger section of the car, otherwise you won't be able to get them when they are needed! 3. Inside the top of the driver's front wheel well, just aft of the spring coil mount, is a little rectangular corner in the black plastic shroud that lines the inside of the wheel well. Reach under this, and you will feel a "wire" about 1/8" in diameter. Too thick for an electrical wire (and not in a harness anyway). Now tug this cable gently out from behind the shroud and get a good grip on a loop of it. Now pull hard away from the headlight once, and prepare to hear the music of the alarm as the front hood pops open. Grab a 10mm wrench and take off one of the battery cables to silence this thing until you can get your key in the ignition and disarm the thing. Disconnect the alarm horn, re-connect something with power to the battery leads, and unlock your car. Mike The cable is behind the right front bumper area - period. Sometimes you can reach between the wheel well liner and bumper and find it. In other cases you need to pull the wheel well liner partially out to find it. The jumper position at the fuse box is also true - but only for MY01 an newer cars. So if you don't have the fuse block connection that is not an option on your car.
  8. I guess you didn't see my previous 5 radio code posts - today alone. Maybe we should stop doing this? :angry: Try 0864 or 0862
  9. Just 5 times today alone - you need to go to Lost Radio Code - post your request here
  10. Um... that is exactly what is on page 1 of this thread.
  11. Loren
    Help
    From the part number - likely a 1980's Porsche 928.
  12. The Retail Price Search feature (for our Contributing Members) has been updated to reflect May 2008 pricing for the US (only). We try and update this on a monthly basis as the price lists come available to us. For May 2008 the price lists support: US: 219,860 parts Canada: 209,209 parts (December 2006) Thanks again to Contributing Member Porschelibrarian!
  13. According to my old 993 manual... Fault code 53 is injector valve cylinder 2 Power supply Disconnect valve plug, connect voltmeter to the injector valve plug terminal (refer to diagram and ground (engine)). Ingition on. Display: Battery voltage If there is no 12 volts there then you need to look at the wiring. Checking coil resistance of injector valves Disconnect valve plug. Check coil resistance at injector valve terminal contacts with an ohmmeter. Test value: approx. 16 ohms If that tests ok then the injector is still likely bad - just the plunger is either stuck or damaged.
  14. According to PET MY01 has a different part number from MY00 and earlier and MY02 and later. MY01 was also the last year of a gloss black finish. The parts list says (only) 996.653.101.08.EFR
  15. Try 2472 or 2470
  16. Try 1343 or 1341 Hi Loren, Just tried this, but it didnt seem to work. Any other ideas? Thanks Russ Hi Loren, Just tried these codes again, but still no luck. Any further codes? Many thanks Russ Please re-read the FAQ... I answered that there too.... :huh:
  17. Loren, my battery is totally dead. I have searched for and read every post on this emergency cable and still haven't been able to find it to release my front hood. I have a USA 2002 Boxster S, have felt everywhere that seems logical in the top of the left and right wheel wells, behind the coil, pulling away the plastic liner. You mention the "left" wheel well, is that also the driver side wheel well on this car? Also, I found instructions both here and on another site that described an unlocking sequence that should have popped my hood, using a battery charger to that red pull out fuse, with the left door open, turn the charger on, the alarm goes off, then push the door latch to the closed position, lock and unlock the door and then open the hood. Multiple attempts at that failed also. Do you have any ideas here? I'm now getting a little desperate. Thanks, Mike Um...
  18. Try 1343 or 1341
  19. Are you sure it is filter and not the foam insulation inside the housing? Check with the car/fan off.
  20. 1. Have the battery tested an auto store (new batteries are under $70). 2. If the battery proves good then I suspect that you have a bad ignition switch. Covered here many times before and there is a DIY for replacement.
  21. Less than 2 hours... No patience eh? Make sure the key is out of the ignition and the battery is disconnected - FIRST. Preliminary work for DME control module in Cabriolet 1. Removing cover over the motor 1.1. To loosen the carpet, pull out the plastic clips with a trim pry tool and take out the carpet. Removing DME control module in Cabriolet 1. Unscrew the four fastening screws 1 for the control module and lift it out. 2. Press in the connector and pull it off the control module A. 3. Press in connector B latch and actuate the latching lever.
  22. Sorry, I still don't see that you have told us the model and model year of your car...
  23. Try 5384 or 5382
