  1. Try 1778 or 1776
  2. I would appreciate it very much if you would NOT post your request 3 times. I have deleted your other 2 requests. Try 5234 or 5232
  3. I agree with Chuck - those sound like Max pressures.
  4. Try 6760 or 6758
  5. You have a modified cluster. Chances are you will need to open it up and see if it just a loose connection (or two) -- or worse.
  6. If your water pumper had failed then it would always be hot. 190 is not that high you have a minor problem. I suggest the following: 1. Are you sure both fans run - one in each front fender well. They have two speeds slow (when the coolant is hot) and fast when the AC is on (or the car is very hot). 2. If you have never cleaned the debris from the front bumper air intakes it is probably worthwhile to do that. Several folks have written up the process here.
  7. Check the electrical connection, coil and even the spark plug.
  8. http://www.renntech.org/forums/index.php?a...=maint_menu_box
  9. Check in this order: 1. Fuses 2. Relays (swap with the other side). 3. Turn on AC - do they both then work?
  10. :welcome: If the brake wear light comes on then the sensor for your pads need to be changed. It is just a special wire that when worn through turns on the light. So, if you did not replace the brake wear sensors then you need to. There is at least two TSBs (Technical Service Bulletin) for airbag lights on MY03, 04, and MY05 Cayennes. You should see your dealer and have them perform the procedure in TSB 9/04 6963 Airbag Warning Light On - Fault Code 1217 and 1218 -- dated Jun 7, 2005
  11. RFM I understand the FWD unit has gear oil and the cardon shaft ( I think) but I still don't see where his leak is coming from - which is my point. I really think he needs to find a shop that put his car on a lift and find the source of the leak.
  12. 1. I have a 3rd radiator Tool Pants does not. Because of the 3rd radiator I chose to mount the horn from single strap (see pics in post 5 of this thread). I believe Tool Pants used the hanging brackets for the 3rd radiator (which are on all cars). It really makes no difference which method you choose. 2. In my method you do not need any bolts - you use one existing bolt and the mounting bolt that comes with the horn. In Tool Pants method I think you would need a couple of M8s.
  13. Try 0704 or 0702
  14. I would not worry about it either. Keep a little anti-seize on the wheel bolts and rinse any winter salt away and you should be fine.
  15. There is no oil in the Tiptronic transmission only ATF (red and lighter than motor oil). So, if you have oil on the floor it is not from the transmission.
  16. Then the leak is from the engine - not the transmission.
  17. Sunset Imports (Porsche Parts at Dealer Cost) - see the link at the top of any page.
  18. Try 4693 or 4691
  19. Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  20. http://astore.amazon.com/renntechorg-20/de...4654593-2783818
  21. Yes, 5/8 inch deep socket with rubber insert to hold the plug. The tool that is a little hard to find is the short wobble extension. Both Sears and Harbor Freight have them for reasonable prices.
  22. Is the leak ATF or oil?
  23. Have a look at TSB 9/99 2015 Carrera 4 – Running Out of Fuel -- dated 10-14-99 "To summarize, if the battery is disconnected with the fuel level less than 1/4 tank, the fuel level and driving range on remaining fuel values will be incorrect. When the battery is reconnected, the fuel calculation will default to 19 liters, when in fact, the fuel level is most likely less than 19 liters. This can result in the vehicle running out of fuel, with a seemingly good fuel level indication."
  24. Hi Loren, If I'm reading this right, a basic 1999 C2 will not have this problem, if the battery is disconnected; or should I make sure the tank is full anytime I disconnect the battery? thanks, Correct it is only 4WD cars where Porsche used the "saddle bag" gas tank. Those would include C4, C4S, and TT.
  25. Fault 21 is: Firing circuit, driver fault. You will need to find a shop with the proper test equipment to safety diagnose whether it is the airbag (in the steering wheel) or the triggering unit.
