  1. Hmm... don't know what to tell you - maybe I have longer arms ;)
  2. I agree with RFM - looks like he/she turned PSM off.
  3. Did you remove the left rear wheel? It will be easier to reach if you do.
  4. The sensors could be contaminated if they got sprayed with oil or something else.
  5. Try 1513 or 1511
  6. Tools Pants can give the details - but yes.
  7. that may be true, but I'd assume that most late model racecars are running the stronger turbo/GT2/GT3 dry sump block That is what the poster was asking about -- an X50 is a 996 TT with the upgraded engine.
  8. GT3 Mk1 wheels were: Front: 18 x 8 ET 52 Rear: 18 x 10 ET 65 GT3 Mk2 wheels were: Front: 18 x 8.5 ET 40 Rear: 18 x 11 ET 63 So I am not sure what you have. You will need spacers either way.
  9. Sorry, I don't think measurements will tell you what springs you have - would only be a guess.
  10. Boxster muffler mounts vary by year model somewhat. perhaps it would help if you said what year/engine.
  11. Well, the previous owner could have always hav changed springs to an after market. I can't think of a way to tell unless you look at each spring and see if it has Porsche's color codes or some other manufacturers part number.
  12. Which wire goes to positive voltage and which wire goes to ground. Since they are LEDs - once side has to be to ground. Conventional bulbs don't matter.
  13. Start by looking are your cars option codes list (under the front hood). Look for M030.
  14. The code calls out bank 2 only. As kbull88 said above check you Maintenance book for your car - as to emissions warranty.
  15. I think that top cap should come off because the accumulator just screws on like an oil filter does.
  16. In most cases O2 sensor "diagnose" a problem not cause a problem. P0430 TWC Conversion, Bank 2 – Above Limit If you erase this code and it continues to come back - then you have a bad catalytic converter.
  17. Hi there, Apart from whether this method described here is ideal or not, I have another problem with it. It generates unnecessary waste. Whether as a 50/50 antifreeze (mostly ethylene glycol = toxic, see :http://en.wikipedia.org/wiki/Ethylene_glycol#Toxicity) or as a watered down version, you still cannot flush it through your toilet, and it will need to get disposed of properly no matter what. Let's do the math: - Assuming you are able to evacuate the entire cooling system by removing under panels, hoses etc. you will end up with approx. 6 gal. of waste. - In the procedure above I count a total of 6 times removing 2 gal. = 12 gal of waste (albeit more diluted). I just ordered the UView Airlift II for $72 delivered from Amazon.com and will give it a try this weekend. Loren: Having mixed orginal Porsche coolant with Prestone premix (ooh ignorant me), would it make sense to use a product like Prestone Super Radiator Cleaner, high in chelating agents, before refilling with Dex-cool? Joost I would just flush and drain with water a couple of times. Vacuum fill is still the best method.
  18. Or find someone with Durametric software.
  19. Use the Mobil 1 synthetic 75W-90 or the Shell. The Shell is easier to find for some folks.
  20. Are you sure you have the polarity correct?
  21. Try 9591 0r 9589
  22. The new design started in April 2000 so he should have that. Per TSB 7/00 3041 Creaking Noise In Clutch Bell Housing Area "The modified release lever was installed in production on April 19, 2000 from the following transmission number: G9600 1018220."
  23. Try 5329 or 5327
  24. Try 6760 or 6758 These didn't work. Does that mean I am out of luck? Lost Radio Code - FAQ, PLEASE READ THIS FIRST
