  1. P0301 Misfire, cylinder 1 You might also want to check the coil pack and spark plug on cylinder 1.
  2. Try 6049 or 6047
  3. Try 4456 or 4454 Loren, does it make a difference if the electronic model is 4362, instead of the BE6624 on the label? That is what mine says. No, only the serial number makes a difference.
  4. I know what it is - I was asking how you fixed it. Thanks.
  5. Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  6. Try 5640 or 5638
  7. There are drains but they are likely pluged. Keeping those drains clear has been discussed here many times. IMHO a bad place to put a critical controller. It needs to be checked with a PST2 or PIWIS tester -- but it does not sound good.
  8. Have you checked the fuses? If there were internal shorts then the immobilizer\alarm\central locking control will likely have to be replaced. That will require IPAS codes and reprogramming with a PST2 or PIWIS.
  9. Loren, Is it o.k. if Kirk and I swap out springs if we use jacks and jack stands? - Kirk, I don't mind coming early at all. I have 2 jacks and 2 jack stands. I can bring those. If you would bring your spring compressor that would be AWESOME. I don't have too many tools either so if there is anything special that you used when swapping yours out could you bring those as well? As long as it can be done safely and within the time the Borden's have graciously donated their shop.
  10. Loren
    MK1 GT3 pics
    :welcome: Nice ride. Have you looked at the Registry? - that is the best place to put pics of your car and mods you have made.
  11. :welcome: Are the brake pads really worn? If so, then the light won't go out until they and their sensors are replaced. Strange dash lights could be an electrical fault (bad ignition switch) or very low battery. Was the car on a battery maintainer over the winter? Never - ever open a coolant cap unless the engine is cold. You are lucky you were not burned. It says this in your Owner's Manual.
  12. http://www.renntech.org/forums/index.php?showtopic=6
  13. Try 4456 or 4454
  14. Last time I ordered a -01 cap I got an -02 cap. The package still said -01.
  15. Try 0379 or 0377
  16. Yes, remove the engine drain plug and the large radiator supply and return hoses on the engine.
  17. If you bought coil-overs - no. You will be replacing the whole strut assembly.
  18. You gave me 3259 and 3261 (I have been in China and only JUST returned to try them out)... Neither code worked! Any suggestions would be appreciated... Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  19. A special thank you to Mary and David Borden. We now have a date/time for this WOCD. The WOCD will be: Saturday June 7th From 10 am to 5 pm Please confirm (by posting here) that you will be there and what tasks we will be doing so that I can bring any special tools that might be needed. If you are doing any maintenance items - I ask that you bring containers to take your waste oil, fluids away and properly dispose of them. And please try to allow time to do your work within the hours posted (i.e. please do not show up at 4:50 pm and say you want to do your 30,000 mile maintenance.). Thanks. Directions: Please PM me for directions (if you do not already have them).
  20. it is going to be very similar to the RoW M030 install - except you won't be disassembling the spring/struts. Your's should be a little easier - just like replacing shocks. Don't forget to get a full alignment ASAP after the install.
  21. Try unplugging it before you start the car and see if the noise is not there. Don't forget to plug it back in or you will get a CEL.
  22. If you have an -01 cap and you still suspect a leak get the cap tested or replace it. A cap leak is usually small - and a cracked tank is usually quite large. Sometime a crack in the tank is impossible to see until it is removed.
  23. Can youplease tel me wher the Alarmcontact spot is? Thank you What is the model number on your radio?
