  1. A cracked head or blown head gasket can be replaced. If you have a porous block then the engine needs to be replaced (exchanged).
  2. Try http://www.oklahomaforeign.com/
  3. You will need to point out which parts you mean...
  4. The switch is in the hood latch release.
  5. :welcome: P1115 Oxygen Sensor Heating Ahead of TWC, Bank 1 – Above Limit Heating current too high – Heating resistance too low – Short to B+ Heating current too low – Short to ground – Corrosion in connector – Break in wiring except for a few small wires Open circuit – Break in wiring – Heating resistance too great Internal resistance of oxygen sensor too high – Open circuit in sensor line – Oxygen sensor
  6. Hi, I also did not get the code card with my used Porsche and the battery went dead over winter. Next year battery maintainer! Any help would be appreciated. It is a 2000 Carrera CDR-220 Type: 4462 Ser: y5040879 24/99 Thanks. Try 0857 or 0855
  7. Read... Lost Radio Code - FAQ, PLEASE READ THIS FIRST Then try 5753 or 5751
  8. hello loren thank you in advance for taking the time to help us in unlocking our radio =) here are my specs cdr 220 becker 1 4462 x5025403 48/98 thanks again ! Try 7114 or 7112 sorry loren both dont work do u have any more suggestions ?? thanks in advance Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  9. hi Loren, thanks for the answer. i just got the scanner from autozone. it now gives me P0507 idle control system rpm high, P1128 manufacturer control fuel air metering, and P1130 manufacturer control fuel air metering. The original code P0430(bank 2) is not showing at this time. now i am wondering if the bad cat. or oxygen sensor had triggered bad fuel/air mix which leads to high rpm (1200-1300) at idle or if i am in deep trouble. any thoughts?? P0507 Idle Air Control at Stop – Above Limit Idle speed too high. – Throttle valve is sticking – Leaks in intake air system P1128 Oxygen Sensing Adaptation, Idle Range, Bank 1 – Above Limit P1130 Oxygen Sensing Adaptation, Idle Range, Bank 2 – Above Limit – Incorrect signal from MAF sensor – Intake air system leaking – Fuel pressure too low – Volume supply of fuel pump too low – Fuel injectors fouled – Exhaust system leaking
  10. If you CEL is on steady it is safe to drive the car. If the CEL is flashing then it should not be driven.
  11. 996.512.988.00 Spoiler -- US MSRP $292.07 I am sure Sunset Imports (Porsche Parts at Dealer Cost) can do much better on price.
  12. :welcome: It would be very helpful (in the future) to give the model year of car when asking questions. MY2006
  13. Try 4845 0r 4843
  14. hello loren thank you in advance for taking the time to help us in unlocking our radio =) here are my specs cdr 220 becker 1 4462 x5025403 48/98 thanks again ! Try 7114 or 7112
  15. :welcome: You need : 996.613.155.00 A05 Thanks Loren. Great forum btw :D Sorry, is there something i have not understood ? Because in the first post, i read : "The switch is part number 996.613.155.00 A02 for a switch installed on the left side of the dash " Thanks. The finish on the early cars switches was glossy - later cars had switches with a matt (flat) finish. You need to get the one that matches the other switches ion your car.
  16. That is what I meant when I told you 640 xxxx is in two model ranges - 914-6 and 1980 911SC. I suspect it is a 914-6 engine (which is fine).
  17. The only place in the list (that I see) a 640 xxxx serial number used is on a 1970 1971 914-6 and 1980 911SC. So then it could be 2.0 liter or a 3.0 liter based on that. Does it have carbs or fuel injection?
  18. Try 4828 or 4826
  19. Try 4753 or 4751 Lost Radio Code - FAQ, PLEASE READ THIS FIRST
  20. Well, hopefully one of them will see the posts here. Just do a member search for "Edmonton". But please also respect their privacy.
  21. Very unusual if a low battery caused an airbag light. I think you need to have the fault read out. I know we have members in Calgary and Edmonton.
  22. So my question is - what caused the light to go on? Did you remove a seat or the steering wheel with the key in the ignition? If not, then I would think it is in your best interest to find out why the light is on. BTW... there are quite a few private owners that have the Durametric software as well as independent Porsche shops that have one of more of those tools.
  23. Why not disconnect the belt (for a very period) and see if the noise goes away?
  24. You need to find someone with the Durametric software, a PST2 or a PIWIS tester. Most importantly you need to read out the fault code as to "why" it came on. Where are you located?
