Leaderboard
Popular Content
Showing content with the highest reputation on 01/09/2025 in all areas
  1. Here is how you replace the spring in the center console on a 2006 997S. The cost of the part was 87 cents. Here is a picture of the part. You remove eight torx screws to get the cover off. This is the cover off. Here is the cover. There were two different length screws but it does not matter where they go. Next you release tension on the spring. I have a torx socket resting on the spring release. The last step is to pull the hinge pin out. I used a vice grip and it worked real nice. Replace the spring and reassemble. This is a very easy task with a difficulty index of 1. I replaced the spring because the console door would rattle over bumps. The new spring works like a champ. Paul
    1 point
