Leaderboard
Popular Content
Showing content with the highest reputation on 09/14/2019 in all areas
  1. This thread will give more info. "Lazy" VarioCam, P1341 - Rennlist - Porsche Discussion Forums RENNLIST.COM 996 Forum - "Lazy" VarioCam, P1341 - UPDATE: IF YOU ARE SEEING SMALL BITS OF GREEN O-RING-ISH RUBBER IN...
    1 point
  2. I haven't tried the Autel scan tool so not sure how accurate it is. It would be nice if you could recheck everything with a Durametric. Assuming the Autel readings are correct, your bank 1 cam deviation is not in spec and should be corrected. You may want to replace the bank 1 chain tensioner and retime bank 1. The bank 2 cam behavior sounds suspicious. Could be the variocam actuator problem (sticky). Would be nice to check with Durametric to confirm before digging in further.
    1 point
