Can the C4S style dual exhaust pipes install on a 2003 C2 Cab? Is this a simple plug and play?
How about the Turbo dual exhaust pipes?
Also, would you have the P/N?
many thanks!!!
It looks like I can install the following for that 4 pipe look?
Four-Tube Sports Tailpipes (Carrera)
Chrome-plated sports tailpipes with elegant four-tube styling. Suitable for 911 Carrera models from 08/02.
Left:
Part no. 996 111 981 02
Right:
Part no. 996 111 982 02
Is this corect?
hi Loren,
I got a pair of dual-pipe tips, but there are no 996.xxx. numbers on those, so how do you know if they are fitting for C2/C4 or 4S?
the only no. are: EP4120 14/02, on one of them.
cheers,
Tony
hi Loren,
cheers,
Tony
Without part numbers or pics it's hard to say. If you can post pics perhaps someone from the RennTech team (or Gert) can identify them.
The Turbo twin tips are 6120 so the ones you have (4120) must be for the C4S or the '02- C2/C4
If the tips are only 10 cm long, they are the C4S version.
When they are about 15 cm long and come with a piece of extention pipe, they are the ones for the '02- C2/C4 cars
thx Gert,
that's it then, they are mounted with an extention pipe like the <MY02 tail-pipes versions, so they have come from the C2/C4 >MY02
this means I got the wrong ones for the 4S back bumper conversion :-(
well well than, I will have check if the new >MY02 back bumper fits my '00 C2 w/o major mods to mount the twin tail-pipes!
cheers,
Tony
The C4S tips I have sitting here are labeled EISENMANN EP7120 43/02 (last part is probably date code, 43rd week of '02 or something).
-Scott
Interesting thread.
This should be the list of the Eisenmann numbers for all the -optional-996 tail pipes:
EP 4110 : big oval 996 3.4L ('99-'01)
EP 4120 : dual tip 996 '02- C2/C4 (no GT3, no C4S)
EP 6120 : dual tip 996TT/GT2
EP 7120 : dual tip 996C4S
Edited by Gert
thx Gert for the complete lists of part no.!
'n another question about mods of 4S look:
so this means, there are needs to get a self made tail-pipes extension for modification from C2/C4 to the 4S back bumper on the original exhausts or to get a pair of 4S exhausts and tail-pipes?
cheers,
Tony
You need a pair of original (or dual) Turbo or C4S exhaust tips because only these tips will match the exhaust contours of the Turbo/C4S rear bumper cover.
The piece of pipe of the original exhaust tips needs to be modified so it connects the new exhaust tips with the original mufflers.
