Have you heard anything about a potential problem with the PASM set up (bushing issue? - Excellence mag article). The writer thinks that there is lateral "movement" at the rear? Do you think this problem is critical?
There is TSB (July 2005) for some stabilizer connecting link mount problems. If you are in doubt have your dealer look at it.
Will this problem be corrected in the MY06s? Thanks.
