Manual Front Trunk Cable
If your battery is dead and you need to get into the front trunk, it may be necessary to locate the manual pull wire to open the front trunk and get to the battery. This might be more difficult to locate the first time. You may not be in a good location to wrestle the right front tire splash guard to find it. It might be night time or you may not be dressed in the correct clothes to be down by the tires trying to locate it. I would recommend that you take the time to locate it in good weat
Edited by kbrandsma
