I have just changed out the standard Becker radio for a kenwood sat nav system. However, when I alarm the car now it gives a quick blast of the horn indicating that not all alarm circuits are functioning. I believe this is because the alarm monitors the stero, and it has changed.
Does anyone know how to get round this?
There is an alarm contact where the radio slides in. It hits sticker on the Becker radio and then loses contact. You need to put some tape in the same position on your new radio.
If you had a CDR23 or PCM2. You have a car with a MOST bus, otherwise the tape trick will work. With MOST bus cars, you will have to have the computer set to "no-radio" by a dealer or someone with a PST2/3.
