How do I replace the air filter?
The air filter element is equipped with 4 plastic clips and 1 screw on the front side of the air filter housing. Remove the screw and pull out the filter element.
I think mine is set up different, notice the cover with two screws, and not a usual slide out filter.
All 987 are the same, i see that you are a contributing member, ask Loren for an " exploded view" from the PET and you will see what i mean.
Item 9 is attach with 1 screw in the middle to the filter element and 4 clips ( pins ) which forms one piece with the filter element. It looks complicated but in fact it's simple.
