Hey guys,
Turns out my new Carrera S (997) doesn't have the short shift installed as sold!! Could just make out the part number on the cage when installing my new 997 Turbo gear knob and it matches the standard OEM, was always sceptical after having the short shifter for over a year in my wrecked Cayman S (same part number for all the Porsche's btw) and just thought it felt different so I'm going to order the part via Porsche and fit myself...
Can anyone post this -> Workshop Manual '340819 Removing and installing gearshift bracket'. as the TSB for fitting refers to this and is pretty vague otherwise... obviously I've sussed the knob removal/replacement thing just don't want to miss any cable tweeks the above may refer to after the install! ;o)
Cheers for any help
Dean
South Wales
UK
The B&M instructions (with pictures) are quite good (and not copyrighted).
You can down them here.
Hey thanks for the heads up Loren, as helpful as ever!
Incidently, where could I get the worshop manuals on DVD/CD to access this?
Cheers
D
