The drivers seat (rhd) in my 01' S seems to have collapsed, Theres very little lower support unlike in the passenger seat..
By feeling around underneath it I can noticed the foams come out little, i can pop it back up but it still falls down next time i sit in it
(im no fat *** lol 76kg)
What can i do to fix it??
Was thinking about removing the front seat but wasnt to sure if its advisable due to the tension of the bolts, is there an easy way to remove the seat?
Not sure if you's can see it in the image
Cheers :)
I have the same problem in my 00' S !
A couple of weeks ago I removed my drivers side seat (rhs) because there was a strange clicking noise in the seat when I stopped and started.
Did find that the pins in the lift cylinder are slightly loose and allow the seat to move slighly.
When the seat was out I noticed a small amount of foam crumbs under the rear right hand side of the seat. This turned out to be from the seat foam coming free from the under side of the seat.
I looked closer and found that some of the straps are loose under the seat.
It would be good if someone know's of a way to repair this problem.
The 4 bolts that hold the seat down are tight, but do come out. With the roof down the seat comes out easy!
Cheers
Stew
You need an E12 Torx socket to remove the seat bolts (but, in a pinch, it can be done with the proper size hex socket). The tightening torque is about 60 lb-ft. Before the seat can be removed, you must unplug the wiring harness. The plug has a latch which pulls out to one side to allow the harness to be removed. DO NOT remove the wiring harness with the key in the ignition. This will set the air-bag light on the dash and it will require a trip to the dealer to turn it off again.
Thanks Fellas, saved me a days worth of headache there
I'll head out and grab that socket, the bolts are incredibly tight, dont want to round the bolt using a hex piece
Will post pics when i get the seat out
Cheers
Edited by 911-996
Finally tracked down an E12 torx socket, didnt realise they'd be so hard to find
Got back, unbolted and removed the seat, only to find the problem isnt so easily visible
Stew did you manage to find where the little wire clips hook onto?
Attached are some pics
Cheers
Edited by 911-996
The under side of my seat looks different to yours.
It has about 4 black straps running from side to side. These are part of the suport I think.
So I can't help with the wire hooks.
No Probs, I think ive sorted it out
Pushed the wire back up behind the plastic and pushed the metal hook in the last pic back into the foam
Feels ok now and seems to take a bit of bouncing around with out it poping back out, will see how it goes
Thx fellas :)
