That is a new style cluster and your 2001 is a new style cluster car. My only question when having a pre-MOST cluster car was if the cluster would work on a post-MOST cluster car due to the radio code. Not an issue for you as your 2001 radio has a user code and your radio is pre-MOST.
Plug it in and find out. He does not say what the miles displayed are so you might have to change it.
Hi Toolpants, thanks for your help.
Mike
Just to add to Toolpants comment regarding the problem of keeping the same mileage on a new or replacement cluster.
I have just changed my stock black cluster to a silver dial version and had 2 problems.
1. The mileage on the new cluster was significantly different
2. My car has the onboard computer option and a clock, the new cluster didn't show the clock or the computer.
It wasn't a big deal, I split both clusters and the dials then just lift out from the circuit board, swapped new dials onto old circuit board and everything now works, computer and clock.
hope this helps
Nik
