I have a 2001 Cab and have never done anything to the convertible top but rinse it down with water. I have noticed this season that the water no longer beads on the top as it did for the first couple of years. Is there a cleaning/treatment solution to use on the top that brings back the bead?
Search the web for RaggTop cleaner and protectant products. They are terrific.
Here you have a copy/paste of how to:
The modern roadster is a masterpiece of beauty, performance, and superior engineering. We own these wonderful machines because they warm our soul. Like you, my blood stirs each time I twist the key and the engine comes to life. Top down, sun on my back, wind in my face, eating up the road... could anything be better?
Unlike coupes or sedans, roadsters and convertibles have special requirements. Where the roadster or convertible’s fully enclosed brethren sport steel and glass, the topless car has canvas and vinyl. This simple difference creates a myriad of challenges for the soft-top owner.
SOFT-TOP MATERIALS
The first thing to understand about your soft-top is its materials. Without this understanding, it's hard to appreciate the maintenance requirements.
Most modern convertibles and roadsters have soft-tops made of a durable polyacrylic/polyester canvas or vinyl. The fabric-like canvas tops feel nice and look great, whereas the vinyl tops are more economical and easier to maintain. Fabric tops have a tight weave, but they breathe. Unlike vinyl tops, a canvas top is not waterproof, it is only water-resistant. To make the canvas top waterproof it must be treated. Without protection, the canvas top is susceptible to leaking and stains. Likewise, vinyl tops need protection from the sun and pollutants. If you're not sure if your top is fabric or vinyl, check with your dealer or the manufacturer.
The rear window on your soft-top is special, too. Many soft-top cars have rear windows made of a clear vinyl. This allows the window to fold. These clear vinyl rear windows will absorb a wide range of gasses and liquids, including water, acids and hydrocarbons. Because it has the ability to absorb foreign materials, it will yellow over time if it is not properly maintained. Most often, the yellowing and discoloration is a result of ultraviolet (UV) light crosslinking. The vinyl is not directly affected by the sun’s UV rays, but what it absorbs can be.
HARMFUL AGENTS
Common cleaning products can be very harmful to your soft-top. Chemicals you should not use on or near your top include: ammonia, bleach, detergent, alcohol and vinegar.
Detergents, bleach and harsh acids will quickly deteriorate canvas, whereas ammonia and alcohol will dry and cloud vinyl. Take my word for it, you don’t want to know what it will cost to replace your soft-top. It makes for a really, really bad day. So please, know the chemicals you use before you apply them to your top.
CLEANING YOUR SOFT-TOP
Your car's soft-top is subjected to the same environmental conditions as the rest of your car. However, where it is easy to see when your car's body is dusty and dirty, it is not always easy to see when your top is dirty, especially if it’s black or navy blue.
Fabric tops, such as the top on this Porsche Boxster, should be washed using a soft brush and a soap that does not contain detergents or conditioners. If the top is properly protected and conditioned, the water will bead.
One of the biggest factors in top wear on canvas tops is dust in the canvas. Dust settles into the weave of the fabric and begins to act like sandpaper. Vinyl tops will also experience premature wear from dirt, but not as readily. In general, you should care for your top each time you wash your car. This does not mean you need to scrub it each time, but a good stiff rinsing is necessary. The following steps are recommended:
1. Wash your soft-top at least once a month (or when it is dusty or dirty) with a non-detergent based auto shampoo. If your top is not dirty, rinse it thoroughly with plenty of cool water. Make sure the shampoo you use does not contain gloss-enhancing oils. If the shampoo contains oils, the top will absorb the oil and become a dust magnet. The Porsche Tequipment Convertible Top Cleaner is an excellent choice for fabric tops.
2. The recommended tool for washing is a soft scrub brush. Do not use a cloth, chenille covered sponge, or lamb's wool mitt, as they will leave lint. If your top has soil marks, stains, or bird droppings, use a small, stiff, natural fiber scrub brush. If you can rub the brush across the back of your hand without scratching your skin, it’s safe to use on your soft-top. Do not use a scrub brush on the vinyl window. It will scratch. Make sure you rinse the top thoroughly with a stiff stream of water to remove all of the shampoo and dirt.
3. On fabric tops, blot dry using waffle weave drying towel. The best method is to use the towel to blot up the water. Don't wipe. Do not use a terrycloth towel or diaper to dry your canvas top, they will leave lint. On vinyl tops, a synthetic chamois or microfiber towel also work well, as do cotton towels. On vinyl windows, quality microfiber towels seem to work best.
SOFT-TOP STAINS
Sooner or later, your top will be inflicted with a stain that will not come out with regular shampoo. Common stains will include bird droppings, tree sap, and grease. For these occasions, you will need to use a stronger cleaner that can penetrate and release the foreign matter.
Your first inclination will be to scrub the stain with the regular shampoo. DON’T! All you will do is spread it around. To remove stains from your canvas or vinyl top, use a fabric cleaner or cleaner made for fabric soft tops. Liberally wet and scrub the stain with cleaner before washing the whole top. Let it soak in, but don’t let it dry. After it has soaked for 3-5 minutes, rinse your top and wash as normal. Rinse the stained area with a stiff stream of water.
WINDOW CLEANING
If your convertible is new, no doubt you have experienced the frustration of polyvinyl fog. Polyvinyl fog is created by the evaporation of plasticizers (an oily hydrocarbon) and other oils. Plasticizers are used in the manufacturing of vinyl to keep it flexible. They are also used in many car care conditioners to rejuvenate vinyl and plastic. Plasticizers remain liquid, and evaporate with the heat of the sun. This off-gassing is worse with new cars, and gradually decreases to a manageable level. Severe off-gassing can also be caused by using too much dressing on your dashboard.
The best tool to clean your convertible’s vinyl window is the synthetic chamois or microfiber detailing towel. Do not use a paper towel, as it can scratch the vinyl. It is best to detail the window (inside and out) after washing the car. Follow these steps:
1. Rinse the chamois or microfiber towel thoroughly with water to ensure it is clean. Wring out most of the water, but leave it damp. If the chamois it too dry, it will not slide across the window. Microfiber towels are not as temperamental.
2. Fold the chamois or microfiber towel into a square.
3. Wipe in one direction across the window. Turn the cloth or chamois, using a clean side with every-other pass.
4. To clean the inside of the rear window, kneel in the passenger seat (roadster) or in the rear seat (convertible). It may take you a few times to learn the best way. The taller you are, the more difficult it will be.
PROTECTING YOUR SOFT-TOP
As mentioned earlier, canvas tops are not waterproof. To make it waterproof and stain resistant, it is necessary to treat it with a protective spray. The only recommended product is RaggTopp.
Although not necessary for waterproofing, vinyl tops also need protection. Using a good vinyl top protectant, you can prevent discoloration damage from road grime, pollution, salt deposits, leaf gum and bird droppings. Make sure you use a vinyl protectant that offers strong UV protection from the sun.
Before spraying your soft-top with protectant, it must be clean and dry. Use a scrub brush and a full .75 ounce dose of top or car shampoo to deep clean the top. Using the canvas top protectant is best done in conjunction with waxing. Your pre-wax cleaner or polish will remove any potential over-spray.
Canvas Top Protectant Instructions
1. Mask completely around your top and vinyl window with newspaper. Once dry, the over-spray from the protectant is difficult to remove from paint, vinyl and glass. Lift the top slightly and slip newspaper between the top and windshield frame. Do the same between the top and side windows. Use masking tape and newspaper to mask the areas where the top and rear panels meet. Use masking tape and newspaper again to completely mask the rear window (do not leave any vinyl showing).
2. Shake the Top Protectant for 30 to 60 seconds.
3. Spray two light coats from about 7 to 9 inches on the whole top. Start in the center on one side and work towards you in even, back and forth sprays, releasing your finger at the end of each pass. Repeat on the other side. Spray a third light coat on the seams.
4. Remove masking materials.
5. Check for over-spray on paint. Remove over-spray with pre-wax cleaner or polish.
Vinyl Top Protectant Instructions
1. Shake the Top Protectant for a few seconds.
2. Do not spray directly to the top. Spray or pour the protectant on a foam applicator or sponge and use the applicator to apply the protectant to your top. Start in the center on one side and work towards you in even, back and forth wipes. Repeat on the other side.
4. Allow the protectant to soak in for 3-5 minutes, then buff dry with a clean microfiber towel or terry cloth detailing towel.
PROTECTING & POLISHING THE REAR WINDOW
Your convertible's vinyl rear window is fairly delicate. It can be easily scratched with little more than normal use or the wrong cleaning tool. Be sure that any rags you use on your rear window are pure cotton. If you use diapers, don’t use it on vinyl. Almost all diapers use polyester thread, which will severely scratch the clear vinyl window.
To protect and beautify your soft-top window, it must be polished. I highly recommend Plexus for regular cleaning and light polishing. Although there are numerous plastic polishes and compounds that work, Plexus is quick and easy. For this reason, you are more likely to use it than a polish that takes a lot of time.
To apply Plexus, use a plush, terrycloth detailing towel or an old cotton tee shirt. Follow these simple directions:
1. Fold your towel into a square.
2. Spray a moderate amount of Plexus on the towel, not directly on the window.
3. Work the Plexus into the clear vinyl, and allow it to dry for 3-5 minutes.
4. Turn the towel to a dry side and buff the window until clear.
5. If small scratches remain, apply a second coat.
If your window has heavy scratches or slight yellowing, use a quality plastic polish.
It is not necessary to use Plexus with every wash, although many people do. If you’re careful with your window, you may find that every other wash, or every third wash is fine. You cannot overuse Plexus. So, don’t be concerned about using it as your everyday cleaner if you drive in a harsh environment.
OTHER TIPS & HINTS
Proper care of your soft-top goes beyond regular maintenance. You can also extend its life and beauty by providing a little extra care when lowering and raising your top.
While the engineers have done a wonderful job designing a top that folds into a small space, canvas and vinyl tops do not always fold flat. It is best to lower the top half way, then smooth the canvas or vinyl to ensure it does not bunch, gather, or buckle.
One of the worst enemies of your soft-top is itself. When lowered, your vinyl window is in contact with itself. As you drive, road vibrations cause the top to rub on itself. Over time, this will begin to leave scratches and other marks on the window. To prevent this, you can use a small piece of fleece or soft cotton (not terrycloth) to protect the window. As you lower your top, after smoothing the wrinkles, lay the fleece across the window.
SUMMARY
Your soft-top can provide many years of beautiful service, but only if you provide it the proper care and handling. Keep your top clean and protect it as needed. When water stops beading on your canvas top, its protection from the sun and water are gone. Vinyl tops need more frequent protection; as often as once a month.
I also thank for the infomation as I have to apply a protecting coat pretty soon for my Cab. Question, is the RaggTop for the canvas top just the same or as good to the one offer by Porsche?
I have a 2000 cab that I just bought a few months ago and it was not beading also. So I bought the Porsche Covertible top Conditioner, which you spray on once or twice per year. Every time I wash it, i use Raggtop Convertible top cleaner. You just spray on the Raggtop after you wet it down and scrub it with a brush, the hose it off. Very simple.
When you use the Prosche Conditioner, you just want to make sure you block off any areas you don't want the spray to get on ( ie. the rear window, painted surfaces, etc...). AFter you use it the top will bead up water for quite a while.
You can get the raggtop and www.autogeek.net . they also have a raggtop conditioner product that probably works just as well as the Porsche conditioner. they also have good instruction on how to clean your top.
you can get the porsche conditioner at www.drivewerks.com. I bought mine through automotion.com, but I can not find it on their website now.
capt601
  • 5 years later...
For those Cabriolet owners with older plastic windows that are clouded, stained or scratched, I have a recommendation for some simple, inexpensive hope-in-a-bottle. Having read all the posts I could find here on RennTech, and then followed up by reading about the various products on the manufacturer or distributor web sites, which included products with three steps, products that only came in entire roof refurb kits, and products that cost too much, I moved on to a broader market research of vinyl window cleaners. The boating and camper industries use these sorts of polishes or cleaners far more than we Porsche owners, so Marine and Camper sites have lots of product information and formulations too.
For me the outcome was this: Vinyl top cleaners are simply a protectant lotion of some sort, with a very mild abrasive. So many of them might be quite good. In the end I settled on trying a Meguiar's product - car specific, with a solid reputation for good, affordable detailing products. On a whim, not wanting to wait for shipping, I called my local NAPA shop. They had Meguiar's PlastX cleaner/polish in stock. Price, $6.49 for a 10 oz bottle. This is a multi-use product that claims useability for covertible windows, headlights, plexiglass surfaces, and, yes, even scratched CD surfaces!? http://www.meguiarsd...tail/MEG+G12310
The rear window on my 2002 Boxster S was not just clouded lightly, it also had vague shadows of paint residue on the outside (like the white paint car dealers use to paint prices on windows or white shoe polish used for a Just Married announcement?), and grundge on the inside near the corners (looked almost like someone had taped something on the vinyl and left the tape residue to decay. The window wasn't horrible, but it wasn't pretty either, while the rest of my low mileage Lapis Lazuli vehicle fairly gleamed. So the less-than perfect window was an irritant I had gotten tired of looking at.
I wasn't expecting miracles from my $6.49 bottle of Meguiar's PlastX, but that's just about what I got. The polishing of the rear window exterior had instant effect. A moistened mini-towel (try a rinsed, damp, baby wipe for this) and some elbow grease had the first layer of film off in a jiffy. The second layer of grundge, the white paint residue, took some extra effort, but to my surprise this came off too. ALL of it! Then I set to work on nicks and on the folded top, driving vibration scuffs. These too polished out!
What was even more surprising, and satisfying was that rather than smearing or caking, the PlastX product seemed to absorb into the vinyl, much the way good skin lotions restore chapped hands in the winter. The inside of the window had some especially tough residues which, given the success on the exterior, I was now determined to remove completely. The entire job took about 1:20, and I did drip sweat from my forehead. I recommend pushing the seats all the way forward, and mounting the hump (so to speak) to get at the rear interior of the window effectively.
The results are nothing less that stunning. I used to wish I had a glass window, circa 2003 on, but now I'm so thrilled with the plastic that I'm reveling in its larger size. The thing shines enough to reflect the garage lights from above!
An added bonus - I was able to use the PlastX to polish the plexiglass rear windstopper which had a few scratches in it. Many of these came out. What's next, my CD collection?
PlastX is also used as a finishing polish for refurbishing clouded plastic headlamp lenses, a task for which Maguiar's has a number of how to videos on their web site.
But try PlastX on your Cabriolet vinyl window! For $6.49 from my NAPA shop, I can't recommend this fix enough.
- 2seatcollector
I'll either vacuum or use compressed air to remove dust/lint etc., then wash with clear water. One in a while I'll use Raggtop cleaner (for fabric tops) with soft brush. I use 303 Fabric protectant which gives me superb beading action for about a year or maybe 4-6 "soapy washes" of the top.
I have found that spraying 2-3 light applications of the 303 in direct sun (as instructed) yields a much longer lasting treatment than doing it in a dark/cold garage in mid-February!
Both products (Raggtop and 303) are available from autogeek.net which is where I purchased mine.
